airbag question..
Old Sep 15, 2006 | 12:42 PM
98hardtopZ's Avatar
Default airbag question..
i have been driving around with no airbag because ive been waiting on an answer but now i need to get it done...would my driver bag blow if i plugs it up backwards? when you plug it in theres two wires, a green and white...or does it matter?
Old Sep 15, 2006 | 12:51 PM
sgt0704's Avatar
there isn't just a standard clip?
Old Sep 15, 2006 | 04:00 PM
98hardtopZ's Avatar
i went from 98 to 01 steering wheel...mine was falling apart and i think those look 100x better, plus i plan on getting an adapter for the radiocontrols...
Old Sep 16, 2006 | 01:51 AM
98hardtopZ's Avatar
anyone...id hate to blow it up..
Old Sep 17, 2006 | 11:06 PM
98hardtopZ's Avatar
cmon guys..
Old Sep 19, 2006 | 04:50 PM
98hardtopZ's Avatar
really need to hook this back up..
Old Sep 19, 2006 | 05:12 PM
RUNINHOT's Avatar
If your worried just stick it in there and dont hook it up.
Old Sep 19, 2006 | 05:14 PM
98hardtopZ's Avatar
i did, now the airbag light is on, and i have a nonfucntional airbag on my dd...
Old Sep 20, 2006 | 07:56 AM
WhiteBird00's Avatar
Ungrounded Moderator
You should find that the 2-pin connector on the airbag has one side larger than the other. In other words, the plastic divider between the two pins in the connector isn't centered so that one pin has more space around it than the other (this is so it can't be plugged in backwards). The white wire goes to the larger space and the dark green wire goes to the smaller space.
Old Sep 20, 2006 | 08:02 AM
98hardtopZ's Avatar
thanks..ill look at it this afternoon..
Old Sep 20, 2006 | 08:05 AM
Make sure you have the AIR BAG fuse removed before connecting the wires to prevent accidental deployment.
Old Sep 20, 2006 | 02:09 PM
98hardtopZ's Avatar
ok...if its plugged in backwards will it blow when i put the fuse back in?
Old Sep 20, 2006 | 02:11 PM
Sorry, I don't know - you're on your own on that one. I recommend you don't plug it in backwards
Old Sep 20, 2006 | 02:14 PM
98hardtopZ's Avatar
haha, thats what im trying not to do...the clips are different but only two...i was trying to figure out if the green or white wire goes on the top of the airbag on the back...i need someone with that same airbag/steering wheel to take a pic of the pic of how it plugs in i guess...
Old Sep 21, 2006 | 01:26 PM
98hardtopZ's Avatar
can someone do me a quick favor and just look where your wires plug in the back of airbag and tell me what color is on top? i think its green but im still nervous about it...
Old Sep 29, 2006 | 02:49 AM
98hardtopZ's Avatar
cmon guys..
