Aux???
Old Dec 26, 2006 | 01:45 PM
SS4Luck's Avatar
Default Aux???
Where are the aux inputs in our cars? I have an 02 SS with the monsoon system, the radio out, yet no AUX??? is it in the rear well by the amp???
Old Dec 26, 2006 | 02:46 PM
MikeFbody's Avatar
Restricted User
there is no aux input, only a cd changer port that can be used as aux input with the right adapters.
Old Dec 26, 2006 | 09:22 PM
VIP1's Avatar
Copy & Paste Moderator
You need a PIE GM9-AUX to convert the CD-Changer port on the back of the headunit into an RCA AUX-IN.
http://www.fadingarrow.com/XMSatelliteRadio.htm
Old Nov 24, 2007 | 08:53 PM
Johns98TA's Avatar
has anybody actually tried one of these units in their own car? How does it switch from aux input back to regular radio? I'm just confused because I was just told by our local car audio place that the aux input boxes only work on factory stereos that have a button for aux or cd changer. Since mine was a regular single CD in-dash unit, it did not support the CD-changer (aux) input. Can someone please clarify for me what will work with my stock stereo?
I want to add an aux input to my stock monsoon head unit. What is the best way to do this?
THANKS!!
Old Nov 25, 2007 | 12:25 AM
VIP1's Avatar
I have the GM9-AUX in my 2001 Formula to connect XM Radio.
You just need a headunit that can control the factory CD Changer:
* 1998-2002 Cassette headunits
* 2000-2002 CD Headunits
(Some mid-late 1999 CD headunits too)
Since you (Johns98TA) have a 1998 CD heaunit, it can't control the factory CD Changer and the GM9-AUX won't work with it either.
Old Nov 25, 2007 | 06:16 PM
Johns98TA's Avatar
Thanks, that is exactly what I wanted to know.
John
Old Dec 9, 2007 | 04:13 PM
Johns98TA's Avatar
OK one more quick question:
Can I replace my 1998 monsoon headunit with a 2001-2002 trans am factory head unit without any other mods?
Old Dec 9, 2007 | 04:36 PM
WhiteBird00's Avatar
Ungrounded Moderator
Yes, it plugs right in.
Old Dec 26, 2007 | 11:34 PM
DesertFox's Avatar
I have been reading up on the posts concerning the aux input using the PIE 9pin adaptor. Basically I have discerned that you can only use the Aux device or CD changer. I have a 1999 Monsoon head unit, and I have the 12 disc changer plugged into the stock head unit (works fine, CD Play button switches b/w single CD and changer). If I unplug the the cd changer and plug in the aux adaptor could that work?
Sorry for bringing this back from the dead.
Josh
Old Dec 27, 2007 | 07:06 AM
Yes, you can plug in the GM9-AUX in place of the CD changer. The adapter has a pass-thru port that would allow you to plug in both the adapter and the changer but only 01-02 models supported having two devices connected. On your 99 you would have the auxiliary and the changer playing at the same time. And that sounds awful - believe me, I tried it. At least you don't have to worry about compatibility - you already have a changer so you know the adapter will work.
Old Dec 27, 2007 | 09:51 AM
DesertFox's Avatar
awesome. Thanks White.
Josh
