Best 10 Inch Sub For A Rear Wall Enclosue Box From Subthump??
Im going to purchae the rear wall enclosure box from sub thump..i want 2 tens..which would be the best way to go..i want it to hit HARD!!! but im not looking to spend A LOT of money..so any advice or opinions will be greatly appreciated..thanks
diamond has a good high power 10". Don't know if it is good for the stealthbox, but I know it and my two 12"s from them are incredibly well built, much better then JL.
Type R isn't bad at all. I guess if you want to be heard from 2 blocks away you'll want something better though. With the hatch in these cars you realy don't need much power back there to sound good.
Not sure what price range your looking at, but I like the specs on the planet audio "Big Bang" 10
800W max
400W
12Hz-350Hz
92 dB @ 1 watt/ 1meter
Dual 2 Ohm
100 Oz
6-5/8”
3”
12 Hz down low should be nice.
http://www.planetaudiousa.com/home/c...um=4&catNum=20
800W max
400W
12Hz-350Hz
Dual 2 Ohm
100 Oz
6-5/8”
3”
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have owned a Type R and IDQ10 and currently own a CDT Audio HD1020....all of them installed in the same ~0.50ft³ custom fiberglass "stealth" box.
I like my CDT Audio the best out of all of them and the Type R the worst of the three. I am more of a SQ guy over SPL though, but my CDT Audio sub gets plenty loud for my tastes. I even have the box STUFFED full of poly to keep the bass nice and tight. I could take some poly out to make it louder but I love the way it sounds right now.
Paul
Paul
