? How to hook up shift lite ?
Old Feb 27, 2007 | 04:48 AM
minesfaster's Avatar
Default ? How to hook up shift lite ?
Does anyone have a shift lite in there car ? I have a 2000 z28 m6. I got a shift lite and dont know where to hook up the green wire. There are 3 wires black (ground) red (power) Green ( ? ) The shift lite is the autometer pro.
Thank you !
Old Feb 28, 2007 | 12:17 AM
KILLER-LS1's Avatar
ya i have a stewart warner digital tach/shift light. you actually hook it up to a wire coming out of the pcm under the hood. ill go check which wire it is tomorrow.
Old Feb 28, 2007 | 05:53 AM
Thank You
Old Feb 28, 2007 | 01:21 PM
dltaskull's Avatar
I have the raptor and i just went to installuniversity.com and i also went to raptor website for the PCM#10 white wire on the red pcm.
Old Feb 28, 2007 | 01:50 PM
SSNISTR's Avatar
Make sure you set it on 4 cylinder mode....
Old Feb 28, 2007 | 03:13 PM
flyinZ's Avatar
Why would you want to do this, Im lost..
Old Feb 28, 2007 | 05:30 PM
SweeTbone's Avatar
Two different threads that will help you.
https://ls1tech.com/forums/showpost....14&postcount=3
https://ls1tech.com/forums/wiring-stereo-electronics/496034-installing-raptor-shift-light-ls1-f-body.html
3 wire hookup. + , - , and Pin #10 right out of the lower (red) connector on the PCM for 1999-2002. For 1998s it's a white wire coming out of Pin #35 on the BLUE connector. It's a white wire that will be tapped and go to the tach signal on your tach/shift light.
Only one wire goes into the engine bay, the tach lead. There is a grommet on the passenger side firewall behind the PCM. You'll have to remove the PCM to get to it. Drop the kick panel on the passenger side floorboard and you're golden.
Both the power and ground will be inside your car. I tapped the pink wire from my TCS switch near my shifter. You can also tap into the fuse box on the drivers side of your dash. There are three smaller slots on the fuse panel, marked ACC, IGN, BATT. The Ignition will be fine, since you only want power going to the shift light when the ignition is on. And as stated, it will need to be set in 4 cylinder mode. It has something to do with the pulses being sent.
Old Feb 28, 2007 | 08:44 PM
KILLER-LS1's Avatar
no you need it on 8
Old Feb 28, 2007 | 08:56 PM
SSNISTR's Avatar
Originally Posted by KILLER-LS1
no you need it on 8
Nope, it's gotta be on 4. If it's on 8 it will be WAY off. Sounds weird, but it needs to be this way due to the firing order on LSx's.
Old Mar 1, 2007 | 01:07 AM
DAMN you guys hella kick *** when it came to helping me out. I really am happy thank you. btw i am drunk as ****. lol
Old Mar 1, 2007 | 11:51 PM
KILLER-LS1's Avatar
you know what, you are right i forgot that!! i got the stewart warner digital tach/shift light and i had to mess with the settings for a while to get it to work
