Infinity 62.7 crossover
Old Mar 7, 2007 | 04:43 PM
Andrew1989's Avatar
Default Infinity 62.7 crossover
I just got my 62.7's and I'm going to install them in the doors ASAP. Do i need to use the supplied crossover? It looks like no, since there is wiring for the woofer and tweeter. So basically; crossover or wire directly to tweeter and woofer connections on the speaker.
Old Mar 7, 2007 | 05:01 PM
3800RS's Avatar
use the crossover
Old Mar 7, 2007 | 06:30 PM
Red97LT1's Avatar
Monsoon already handles this for you.Some use them,some don't.
Old Mar 7, 2007 | 07:22 PM
dragonrage's Avatar
No, you always have to use the crossover that comes with a component set. Every component set has its own crossover designed to work with that system.
Old Mar 7, 2007 | 07:26 PM
fredmr39's Avatar
Monsoon does not handle this for you.
Old Mar 7, 2007 | 07:52 PM
Andrew1989's Avatar
Alright if i am supposed to use the crossover could someone briefly explain how i wire the + and - for both tweeter and woofer into the crossover. Sorry for being so meticulous, just that these were a birthday present and i dont want to take any chances.
Old Mar 7, 2007 | 07:59 PM
Red97LT1's Avatar
Oh,
I was just going by this thread...http://www.ls1.com/forums/showthread.php?t=29204
Old Mar 7, 2007 | 08:08 PM
fredmr39's Avatar
What do you plan to power them with? factory amp? -choose one set of wires then at the doors, probably the set that runs to the woofer... it will be underpowered by a good amount though, so if you have and aftermarket HU - use that....even then, not as much power as you would LIKE to have... Amping them separately is by far the best option, IMO.
Old Mar 7, 2007 | 08:12 PM
fredmr39's Avatar
Oh,
hmm.....I was under the impression the tweeters "crossover" in the stock setup was simply the capacitor at the tweeter itself...
http://www.sonicelectronix.com/item_4296.html#
I thought 62.7i's were 2 way coaxial type speakers...but they supply crossovers? I'm kinda confused...
Old Mar 7, 2007 | 08:35 PM
dragonrage's Avatar
Either way, you use what they come with, not what the car already has.
Old Mar 8, 2007 | 08:53 AM
WhiteBird00's Avatar
Ungrounded Moderator
Oh,
There's a lot of misinformation in that thread (that whole site actually). For example, the tweeters aren't "high impedance" - they're 4-ohm. And, as fredmr39 said, the crossover for the tweeter is on the tweeter...the amp sends an unfiltered full-range signal to them.
