Right Turn Signal
Most of the time this problem is caused by a burned out bulb - especially the front bulb. The easiest way to check is to turn on your hazard flashers and walk around the car looking for the lamp that doesn't flash. The front is suspect because they tend to get water in them. You should also check the bulb socket because that water causes corrosion that will prevent the light from working properly. If the corrosion isn't too bad then clean it out and apply some dielectric grease to keep moisture out. If the socket is too far gone then you can get replacements at the local auto parts store for about $10 each.
