Old 04-29-2016, 05:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
How you can add an aux input/mp3 player without an adapter
Old 09-09-2009, 06:26 PM
  #241
Jason Novak's Avatar
I don't think I've seen the insides of a chevy tape unit. I did mod a pontiac tape deck here:
https://ls1tech.com/forums/7692848-post48.html
In that case it was on the smaller connector, and not the larger connector like the CD player. You can try to verify with the details a few posts up, #236
Old 09-09-2009, 06:30 PM
  #242
Eiyse98ls1's Avatar
i was looking at that but then the smaller connector has 5-6 difrent colors..
Old 09-09-2009, 06:36 PM
  #243
At last on the chevy CD connectors the colors did change over the years, but the positions stayed the same... could be different from the Pontiac unit though. Perhaps someone else has done one ... you can also test them to verify.
Old 09-09-2009, 08:14 PM
  #244
Eiyse98ls1's Avatar
k. after reading through more post i think imago through the cd changer out back.. is the wiring going to be the same? also for ground can i just find a screw somewhere in the area i decide to mount the jack or should i splice into the ground where the connector is?
Old 09-10-2009, 09:31 AM
  #245
If you have a CD changer then it's easier to tap into the harness using the same type of jack ... I don't know the wiring though, but there are other threads here that explain that.
Old 09-10-2009, 01:28 PM
  #246
Eiyse98ls1's Avatar
i have the wiring.. so how would the jack connections be? say i cut the left channel on the connector..which would be considered the wire comming from the cd player module or the wire from the circuit board?
thanks
Old 09-10-2009, 02:21 PM
  #247
This thread has some more details, I don't recall if there is another one with more details:
https://ls1tech.com/forums/stereo-el...0-gm9-aux.html
I would say the end of the wire going to your changer would be the "cd module", and the other end going into the stereo would be the "circuit board"
Old 09-10-2009, 04:41 PM
  #248
pentavolvo's Avatar
100% correct
Old 09-10-2009, 04:50 PM
  #249
Eiyse98ls1's Avatar
Originally Posted by pentavolvo
100% correct
thanks alot.. i got them wired in except for the ground should i just use the splice connectors like the others or just ground to chassis/ HU somewhere..
also im taking pics along the way.. for those who want to use the changer connector instead which is (C2)...
Old 09-10-2009, 05:03 PM
  #250
pentavolvo's Avatar
i would ground to chassis of radio
Old 09-10-2009, 05:05 PM
  #251
Eiyse98ls1's Avatar
thanks..
Old 09-13-2009, 12:32 AM
  #252
critt50's Avatar
I ran into a problem after doing mine. Any help or advice???
https://ls1tech.com/forums/stereo-el...-fm-radio.html
Old 09-13-2009, 04:53 AM
  #253
Eiyse98ls1's Avatar
the only thing i can think of is that a wire is pitch somewhere or ground is bad.. make sure to recheck everything and that your ground is on the chassis somwhere.. also for me i just did mine but i went through the cd changer so if you went inside the HU i would think one of the wires in the inside is loose. i would open it back up and recheck.. if all is good try going back to stock to see if it corrects your problem then you know its the wiring you just did...i know thats going to be a PITA but may help you solve your problem..
Old 09-18-2009, 04:46 PM
  #254
Were you able to fix this? My first though would still be the antenna, not really up on frequencies, etc but maybe it's able to get AM signals even with a disconnected/poor antenna connection. It's very strange you'd lose just one band, and this mod doesn't really have anything to do with the radio part. You should be able to completely disconnect the CD module and the radio would still work.
Old 09-21-2009, 03:55 PM
  #255
dencam7's Avatar
Ive studyed this thread from the beginning . My 12 disk changer will not play in my 2000 Pontiac Trans Amm Ram Air. Cleaned head with a q-tip & alcohol. Ran a head cleaner . I did get it to play one disk after the cleaning with alcohol. Then it quit again. I ended up pulling the radio and splicing into the cassette. It was the smaller connector as Jason said and it plays great. Thanks to Jason and all that helped me!!! If anyone knows of someone that can fix the stock changer please let me know. Id like to have the stock changer working. Does anyone know what after market changers woulds plug right inTo the stock wiring. The unit that is in their is a Pioneer. Thanks again for all the information!!
Old 09-22-2009, 05:28 PM
  #256
blAz3D's Avatar
Just did this and it worked great. Only problem is once I put the radio back in I realized the clock doesn't light up anymore and the seek button is dim. I'm guessing I killed/knocked out one of the lights. Anyone have any other ideas?
Old 09-23-2009, 09:48 PM
  #257
trenz_em's Avatar
Default how to remove the system
how u guys able to pull out the system without getting it locked .
Old 09-23-2009, 11:44 PM
  #258
pheer's Avatar
unlock your car then pull it out?
i jus unlocked the car and pulled the thing out....obviously... didnt unplug the battery or anything (i kno i' should have)
Old 09-24-2009, 01:29 AM
  #259
foxrox0620's Avatar
Just did this on my 98 then had to sell it, anyone get it to work on a lt1? This is a Bose from my 95Z btw. I see 8 brown wires that go from the cd side to a few different locations.
Old 10-08-2009, 04:30 PM
  #260
swaggard's Avatar
ok im lost in this radio. i have a 2000 camaro. i try to splice into 2 sets. Please help me with this
Quick Reply: How you can add an aux input/mp3 player without an adapter
