?'s about Subthump Stealth Box
Also what Sub are you currently running in it? Pro's/Con's of the Sub and Box? How much wattage are you giving the sub?
I have decided to buy a subthump box already. I am just having a hard time finding a 10" sub that will take 700-800watts daily that isn't over $120. So any help or recommendations are appreciated.
Thanks,
John
The subthump box is pretty small for 95% of the 12s out there... there are only a few that would work WELL in such a small enclosure.
Here is a 10" woofer that will handle 1000 watts of clean power:
http://www.tcsounds.com/tc1000.htm
It is $159 shipped though. It will also work in as small as a 0.4cF box. Subthump's box is 0.6cF.
I would be most concerned with getting a sub that works well with the volume available from that box. You could always invert the sub so depth really isn't that much of an issue. Take that for what it is worth since I dont have experience with this box, but inverting a sub has zero effect on performance.
This is the only sub that comes to mind close to your budget -- minimum recommended airspace is .7 cu.ft.......subthump stealth is .6 cu.ft as mentioned.......close as you're gonna get I think. Depth is fine as well.
http://www.edesignaudio.com/edv2/pro...products_id=31
An IDQ is the best option, but its $159 I believe. It will work in 0.35cF up to 0.70cF.
My buddy had a 10" L7 in a stealth box and the sub actually rubbed the t-tops a little bit under high excursion. If the cone will rub, I doubt you can get the basket and magnet to fit
The box actually has a fair amount of depth to it, just no volume.
• 400 watts continuous power (1200 watts peak)
-thats what I saw, and assumed if they said 1200 peak that 1000RMS is a little much.....
Their rating is a 24 hour period of running 400 watts! If they can take 400 watts for 24 hours, they can take a couple hundred more watts for 1 or 2 hours
Very underrated drivers
I don't know if it is "the best" because "the best" is a subjective opinion. There isn't really one "best" subwoofer out there. I think you'd be pretty happy with a TC-1000 though.
