Pre Amp outs from Factory Head Unit ??
Has anyone ever tried to pull preamp outputs from the Factory head unit? This was a trick that has been used in earlier model factory HU to keep the factory appearance but upgrade all the amplifiers and speakers. I'd like to do this with a new HU to drive my amps but don't know where to tap into the preamp section of the HU.
Any help is greatly appreciated,
-Chip
-Chip
Just pick up a line-level adapter from a shop -- this converts speaker-level outputs of the head unit to the pre-amp input that most amps like to "see"...some amps actually have speaker-level inputs as well.
I've already tried the line-level converter, I have a PAC-1. It's not good enough for my SQ system. The factory power amp section has too much noise, I need straight pre-amp without going through the power amp section.
Thanks,
-Chip
Thanks,
-Chip
Thanks,
-Chip
Thanks,
-Chip
A huge waste of time IMHO. The factory HU is a POS. nothing is going to help it sound good. If you did not like the sound quality using a line level converter nothing is going to help except gutting it all and redoing the entire system. I tried but by the time I got the SQ I wanted I had ripped everything out and started over.
Thanks, but I think all the aftermarket HUs look like POS.
you need to specify what you're going for. if you have a factory hu, are you using the factory amp? are you using factory speakers? if everything is aftermarket but the HU, try your method the a higher end converter, but if it still sounds like ****, then you're gonna have to upgrade the HU. there's some pretty cool ones too. i'd prefer a dbl din dvd player. but that takes some modification to make it look right.
Originally Posted by Walking-dead
You may not want dolphins and race cars as screen savers...
that has always confused me....
Yeah, my kenwood has a dolphin fedish too. Anyway I would mostly agree that after market HUs look like ***, but its because of the crappy install kits placed around them usually. My kenwood looks pretty good and matches fairly well, but it will look a lot better once I get a humount for it. Hopefully ill be ditching it altogether for a nav system but if you really think after market HUs look like *** then take a look at some of the pictures of members HUs with a humount, they will change your mind. They really wind up looking very factory and VERY cool.
Ok, but lets be clear about this!! Basically it's the install that looks like crap...the way we have to put a single din unit into a 1.5 din hole. The HU's themselves are not the issue. If that's the problem I'd go double din and redo the bezel. Or a single din and again..redo the bezel. This makes it look factory and fills the hole in. It also gives you the answer to sound quality issues. There are several options...just gotta be a little flexible...lol!!
I agree that most single DIN radios don't look right in the fbody dash but I'll take sound quality over looks anyday.
