Head unit question
Old Apr 10, 2007 | 09:29 PM
Camaros710102's Avatar
Default Head unit question
Is there any HU's on the market that will work with stock speakers and steering controls???????
Old Apr 10, 2007 | 10:00 PM
MikeFbody's Avatar
Restricted User
yes, just about all of them. Well, if the head unit comes with a wireless remote, then it can be made to work with steering wheel controls. And any head unit will work with the stock speakers.
Old Apr 10, 2007 | 10:03 PM
VIP1's Avatar
Copy & Paste Moderator
Replacing just the headunit is easy... its in the FAQ too:
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
You need:
* Mounting Kit
* Wiring Harness
* Steering Wheel Control Adapter
If your headunit has wired remote input, you can use a PAC SWI-?. (The ? is to denote the manufacturer-specific unit. Example: PAC SWI-PS works with Pioneer and Sony.)
If your headunit does not have a wired remote input but it does have and IR remote, then you can use the PAC SWI-X. Its the universal IR steering wheel adapter.
Old Apr 11, 2007 | 07:47 PM
ls14thefun's Avatar
if it is a stock monsoon system it will be a litle tricky. is it or not?
Old Apr 19, 2007 | 11:07 AM
VIP1's Avatar
No its easy.
The Monsoon headunit is a regular gm headunit that provides speaker-level outputs to the Monsoon amp. You can replace it with any aftermarket headunit that has an internal amp (almost all do).
Read the FAQ and do some searching for more specifics.
Old Apr 19, 2007 | 03:33 PM
95_transam_lt1's Avatar
i think there are like 5 or 6 made special for that
Old Apr 19, 2007 | 04:43 PM
KEE AUDIO's Avatar
One of the easiest installs you'll ever do!!
Old Apr 19, 2007 | 10:02 PM
VIP1's Avatar
5 or 6 special what made for what?
