System for my SS opinions please...
Old Apr 17, 2007 | 11:18 PM
CaMaRo67RS355's Avatar
Question System for my SS opinions please...
ok well after ive blown up 3 out of the 8 speakers in my car and broken my monsoon headunit cause i was pissed and decided to hit it. i want a system in my car. the headunit im getting is the Alpine CDA9883 (this time i wont hit it).
-as far as subs i want (2) kicker 10's comp vr's probably but if yall think i should go with something else let me know.
should i go 2 ohm or 4?
-now for highs and mids what speakers do you recommend & what sizes do i need?
-i want to replace all the oem ones, i also want good quality stuff no cheap crap. im not stereo smart so will i need capacitors or what?
-how many amps would u run? 2 one for subs and one for highs and mids?
-what sizes?
***let me know what yall think cause like i said im not really into the whole stereo side of the car.
thanks, Hunter
Old Apr 17, 2007 | 11:43 PM
The Postman's Avatar
You've got the right idea...def go with one amp for the sub and one for the highs/mids...you want amps so that you can adjust the high/low pass filters...this way the sub only plays lows and the highs/ mids aren't getting signals that are toooo low....as far as the subs go, I might not be sure but i think that the lower the ohms, the less power it takes to push the sub..but im not sure on that..but im thinkin the lower the better, just make sure it matches up with ur amp, don't run a 2 ohm speaker on a 4 ohm amp...make sure its setup right, the subs come with directins....read um!! a buddy of mine has only one 10 in a stealth box that fits in the cubby hole in the trunk on the driver side and it THUMPS!..you'll have tight bass that won't rattle ur trunk and it'll make the rock music sound sick ...I must say im jelous on the head unit cuz thats the exact one i want for my Z, but that'll have to wait....as for the speakers..go Type-R component in the front and type-R's in the rear panels and behind the seats....im thinkin you won;t need a capacitor cuz i ran a type-S 12 in my Z with a 700 watt amp and had no problems at all.....but thats up to you. hope this helps
Old Apr 18, 2007 | 06:20 AM
dc160lti's Avatar
Starting with the hu, in my opinion alpine is a good choice. It is kinda pricey but alpine has some good stuff from experience except for the older type x subs. But anyway, on to the subs, what kind of bass do you want? Do you want tight crisp bass or do you want earth shaking bass? 10" subs give you the crisp end of bass and 15" gives you the earth shaking bass and the 12" falls a little bit in between. For the name brand you cant really ask what the best is everyone is going to have their own opinion. I have a 12" orion h2 2ohm and can be wired to 1ohm and a 1000 watt amp, and it shakes the crap out of me. Highs and mids get the same size speaker that comes factory in the car the audio place you go to can tell you the right size. For the cap I have heard you want one farad per 1000 watts, or you could get a high output altenator and upgrade your charging system. If you run two amps you will need a power distribution block, it just splits the power wire from you car battery into to so you can run it to two seperate amps. The size of the amp depends on the size of you speakers. You dont want to under power you speakers because it can damage you speakers. I cant think of anything else to write if you have any more questions just ask. I also have some audio stuff for sale.
Old Apr 18, 2007 | 06:48 AM
what component speakers have yall had good experience with? wat do do you think of the comp vr's? how big of a amp should i run for the subs and the highs and mids?
Old Apr 18, 2007 | 06:54 AM
dc160lti's Avatar
I have been running alpine type-r and when I bashed the subs it wasnt the type x it was the old type r. I have heard good things about the comps, what is the RMS wattage of the speakers you are talking about?
Old Apr 18, 2007 | 02:21 PM
800/400 per sub
Old Apr 18, 2007 | 02:59 PM
KEE AUDIO's Avatar
PM sent!!!!
Old Apr 18, 2007 | 06:04 PM
FireSilverLullaby's Avatar
Sounds good, i just got a hifonics amp. You might want to consider getting the 9885 its got 4volt preamp outputs, and supposley a nice display.
Heres another nice HU from pioneer, it also has a usb drive so you could hook up a hard drive to it.
http://www.crutchfield.com/S-sEYWPQa...300#morephotos
Old Apr 18, 2007 | 06:26 PM
95bat's Avatar
You need to set a budget before you get into car audio.
You said you don't want cheap crap, but that can cost you $500-$600 for a set of components easily. An amp can cost another $500 to power your highs, too.
Budget is most important, then the recommendations can begin.
Old Apr 18, 2007 | 06:44 PM
well im not rich but i want quality stuff. i dont want anything like a stereo competition would have i dont have a need for all that. i want good qaulity sound with good bass. dont really have a set price range yet i want to see what yall think and i'll narrow it down one step at a time from then on.
Old Apr 18, 2007 | 06:46 PM
95bat's Avatar
No offense, but to be honest, that sounds like a big waste of time.
I guess you're stuck with the "alpine is the BEST!!!!!" recommendations until you can set a budget for yourself.
Old Apr 18, 2007 | 06:49 PM
for a 6-disc changer, three sets of alpine type-s speakers, a type-s 12, pro box, 800 watt pioneer amp, 400 watt alpine amp, wiring kit.......cost me about 2000...so ur gonna spend some cash so just get ready for it..and don't believe that alpine is the best...i personally love the **** but its all in what ur lookin for.
Old Apr 18, 2007 | 06:58 PM
im thinking infinity kappa highs and mids and then i just started reading about cdt's... i know i want kicker subs. as for the amps i dont know what kind or size.
Old Apr 19, 2007 | 11:27 AM
bbal4now's Avatar
As far as amps are concerned I like Kicker myself. A 600.1 would get the job done for your subs (I dont especially like the comps but that is up to you). For mids and highs Kicker's 350.4 or 650.4 will do depending on what components you get. I would suggest component sets from either kicker or memphis. Kicker RS65.2 components are reasonably priced and sound great. Check e-bay for some really good prices on some quality equipment. Also if you are in the market for a kx650.4 or kx350.4 or kx600.1 pm me, I have some for sale.
Old Apr 19, 2007 | 12:07 PM
I agree..not a very big fan of the kicker comps...or comp VR's...buddy of mine had 2 of them and he blew them without a lot a trouble.....he only ran one 800 watt amp....
Old Apr 19, 2007 | 01:21 PM
i was also looking at 2 10" solo baric 7's
Old Apr 19, 2007 | 01:22 PM
+2 on the solo's...they sound pretty good and can take a beatin...i'd go with those
Old Apr 19, 2007 | 06:55 PM
MikeRotorsOnline's Avatar
I recommend getting a stealth subthump box. They cost around $90-$100 if I'm not mistaken.
I purchased one years ago for my Alpine 10" DVC Type-S. I am very happy with it.
They make other goodies too. Check them out.
www.subthump.com
Old Apr 19, 2007 | 07:01 PM
KEE AUDIO's Avatar
They also do a stealthbox for the solobaric sub or at least they used to.
Old Apr 19, 2007 | 08:42 PM
thanks for the link guys... any other suggestions...
