Sereous remote start issue
Old May 23, 2007 | 10:41 AM
1FSTLS1's Avatar
Default Sereous remote start issue
Ok so my remote start on my 99LS1 M6 car was working fine. Now it wont start with the key??? I have looked at it several times and gave up. The ignition seems ok. If the car is running I can crank the key and the starter will grind. When I turn the key the ignition and light come on but no engine cranking. The remote start starts the car fine. I want to fix this any ideas?? At least it would be harder to steal the car. Pleas help any thing.
Old May 23, 2007 | 10:47 AM
xBROKEx's Avatar
sounds like you clipped the wire that goes from the IGN to the starter instead of splicing the line from the remote start kit in you must have put it inline
Old May 23, 2007 | 12:29 PM
1FSTLS1's Avatar
Hmm. But why would it have worked ok for like a year then this? Thanks for the input
Old May 30, 2007 | 01:32 PM
greenherb's Avatar
whats the brand of remote start... did you install it yourself... is the remote start fully closed like a clifford intellistart or a external relay unit like the dei 551T
Old May 30, 2007 | 02:07 PM
1FSTLS1's Avatar
Yea i installed it. Not sure on the brand its a cheap one. Fulley enclosed
Old May 30, 2007 | 06:42 PM
WhiteBird00's Avatar
Ungrounded Moderator
Did you use one of those ScotchLock connectors to tap into the starter wire? Those have been known to cut almost completely through the wire when installed. With time and vibration, the wire could have come apart leaving only the wire from the remote starter connected on the starter side.
Old Jun 1, 2007 | 05:38 PM
1FSTLS1's Avatar
Yes I did use them. That is a good thought but would that be the case? It will start while the car is already running. Turn the key while the car is on and starter will grind. Some times it runs better if you start it twice!!! Thanks
Old Jun 4, 2007 | 05:57 PM
1FSTLS1's Avatar
Ok just started tearing it appart again. Dam this thing is pissing me off. So i did not use scothc locks on the starter connection it is hardwired all conections are perfect. I checked the starter wire on the car and from off to start it is getting 12votls as long as i hold the key turned. I have continuity between the starter wire under the dash and where the starter relay under the hood is. I need to see if i get 12v at the starter relay but i can not do it by myself my arms are too short. Dam this thing is pissing me off. Any more ideas before i go crazy. At least this is challanging right! Thanks for the input so far.
Old Jun 4, 2007 | 06:26 PM
1FSTLS1's Avatar
Any one want to buy a 99 silver Z28 in mint condition?
Old Jun 5, 2007 | 02:55 PM
exstanger's Avatar
Have you tried taking it off and trying it. Also have you tried the other key, maybe the chip went out in the one you are using.
Old Jun 6, 2007 | 07:01 AM
1FSTLS1's Avatar
I tried unhooking all of the wires from the brain and still nothing. And yes I did try the other key. Any more ideas??
Old Jun 8, 2007 | 09:23 PM
TheBiz's Avatar
Sometimes the remote start brain and the alarm brains are the same. If the remote start unit accidentally (power surge, battery reset, etc) gets tripped in to the alarm mode, it will kill the starter from the ignition as if it thinks the alarm has been set off. Look through your owners manual to see if the "alarm" option can be turned off on your particular model.
Old Jun 20, 2007 | 07:38 AM
1FSTLS1's Avatar
$100 to any one who directs me to the problem. Also the starter wire gets 12v when i turn the key
