Help on Monsoon. Uninstalling it.
Old Dec 2, 2007 | 10:40 AM
bene's Avatar
Trunion King
Default Help on Monsoon. Uninstalling it.
What is that cable behind the unit. 1/4" black cable (it has yellow band). Where can I disconnect it?
Old Dec 2, 2007 | 10:44 AM
michaelg589's Avatar
The antenna cable? It just pulls out of the back of the HU.
Old Dec 2, 2007 | 11:07 AM
bene's Avatar
Trunion King
Will I able to put that cable back into that hole after I pull it?
Old Dec 2, 2007 | 11:13 AM
yes. the same way you pulled it out. its like plugging into a wall outlet.
Old Dec 2, 2007 | 11:18 AM
bene's Avatar
Trunion King
Thanks for the quick response.
Old Dec 2, 2007 | 12:36 PM
SparkyJJO's Avatar
If you are putting in an aftermarket HU you'll need an adapter, GM has this funny mini plug. I got mine from ebay, an antenna plug adapter for GM cars.
Old Dec 2, 2007 | 12:52 PM
bene's Avatar
Trunion King
Yep, going to need an aftermarket HU. I tried to fix my monsoon and failed. CD function decided to head south. My Ipod is useless now. Looks like I'm going to sell my GM adapter I pod harness.
Old Dec 2, 2007 | 01:34 PM
SparkyJJO's Avatar
I have a monsoon deck if you want it.... a little rough on the outside (couple of the small ***** have some small cracks and needs the bulb for 2 and 5 replaced) but you could probably pull those from your dead monsoon. Just tossing that out there. I know I won't want it again. Thing is it is at home, I'm here at school, won't be back home until the 14th after finals. Of course aftermarket HUs are definitely better.
