Foglights went out
In a Camaro, the ON indicator light gets power right at the switch so it really only indicates that the switch is working. That probably means that your fog light relay under the hood is bad.
In a Firebird, the ON indicator light is powered from downstream of the relay so it tells you whether both the switch and the relay are working. In that case there has to be a wiring problem between the relay and the lamps or the lamps have bad grounds.
