how does this setup sound?
Old Jan 27, 2008 | 05:44 PM
99FormulaM6's Avatar
Default how does this setup sound?
Pioneer DEH-P5900iB H/U http://www.crutchfield.com/S-hdHLHtA...x?i=130DEHP590
Infinity Reference 6012i in the doors
Infinity Reference 6022i in the sail panels and
Infinity Reference 5022i in the trunk
hopefully it will be good, because its in already...
problem was the front speakers were blown about a year and a half ago, and the 6012's were what replaced them... but then all the speakers blew, and the 12 disc stopped working. So the 12 disc was exchanged for the H/U and the 6022's and 5022's were what replaced the stock speakers. Everything was rewired, so nothing factory is in play anymore
Old Jan 27, 2008 | 08:54 PM
Eskimo's Avatar
If it sounds good to YOU, that's all that matters.. really.
Old Jan 27, 2008 | 09:07 PM
hell, the monsoon sounds good to me... i was more wondering if on paper the setup would mesh well..
Old Jan 27, 2008 | 09:13 PM
pentavolvo's Avatar
personally i would have skipped on trunk speakers but all and all should be way better then stock
Old Jan 27, 2008 | 09:26 PM
zypher's Avatar
i really liked my infinity's that i had in the trunk, until my sub woofer rattled them to pieces. they were really loud and very clear. they actually overplayed my 6.5's in the door, and they were over 6 feet away from me. i would imagine it should sound pretty good.
Old Jan 28, 2008 | 09:34 AM
i still need to figure out the H/U bc i cant seem to get some bass out of the speakers. its more highs than mids/lows.
Old Jan 28, 2008 | 09:37 AM
dragonrage's Avatar
That's Infinity for you. Also, how are you powering the speakers?
Old Jan 28, 2008 | 09:56 AM
Gordon0652's Avatar
If you plan on powering the Infinity speakers off the factory amp, your better off keeping your factory speakers.
I had JBLs in the doors, hatch, and re-wired the sail speakers to play full range, connected to the factory amp, and an alpine HU, and the JBLs faded out quick, so i invested into an alpine full range amp, i also read the stickies to fugure out what color went to what speaker, so i knew which wires to cut, in the end they became MUCH louder, and had a cleaner sound. I set my filter on the HU at 80hz so my speakers wouldnt play down pasted that, and had two 12" subs take the bass. The subs filter was at 120hz.
Goodluck, hope that helps.
Old Jan 28, 2008 | 10:17 AM
i do not believe the factory amp is still being used. i will have to check on that when i get home. it still gets loud, but not much bass
Old Jan 28, 2008 | 10:27 AM
dragonrage's Avatar
Sub LP @ 120Hz is WAY too high. 100Hz is MAXIMUM, but 80-90 is better unless your front speakers can't play that low.
Old Jan 28, 2008 | 01:48 PM
Gordon0652's Avatar
Thanks for your opinion...
120hz sounds great when i have the gain set at a minimum and set high around 50hz. I have an external power crossover to set gains at different frequencies, sorry i for get to say that.
No 120hz is not to high if its set up right.
Old Jan 28, 2008 | 01:49 PM
dragonrage's Avatar
Unless you have subs IN your speakers (like in home audio, or if you had say kick panels with smallish subs), then 120Hz is too high. Period. You can call it my opinion but you're not going to find many reputable people running their subs with a 120Hz LP.
Old Jan 28, 2008 | 02:21 PM
Gordon0652's Avatar
No i do not nave subs in my speakers. I have never heard of that for car audio.
If its too high then why can some JBL subs that are 15" hit 1000hz?
And why can some mono amps hit that high also?
What would be the point of that?
I have the sub set at 120hz because it sounds fine to me, and thats what matters.
Old Jan 28, 2008 | 03:43 PM
fredmr39's Avatar
Well what did you mean by "Everything was rewired, so nothing factory is in play anymore" ??
Old Jan 28, 2008 | 03:47 PM
well, they said they rewired everything. Took out the stock H/U and speakers and rewired it all.
Ive gotten it to sound pretty good..i just cant figure out how to set the damn clock.
Old Jan 28, 2008 | 04:01 PM
fredmr39's Avatar
Who knows what they did then...hopefully you figure it out at some point. Sorry I was unaware that you took it in.
Not familiar with that exact model, but if its like my 880, set the clock with the unit off (as in, tuner/cd off)
Old Jan 28, 2008 | 04:09 PM
fredmr39's Avatar
If you're too lazy to bust out your owner's manual, here are instructions from it found on Pioneer's web site:
unit should be off
1. Use your MULTI-CONTROL to select clock. Push or push&hold the button until a menu appears. Then scroll with the MULTI-CONTROL to the clock screen.
2. Push MULTI-CONTROL left or right to select the segment of the clock display you wish to set.
- Pushing MULTI-CONTROL left or right will select one segment of the clock display:
Hour---Minute
- After you select segments of the clock display the segment selected will blink.
Old Jan 28, 2008 | 04:19 PM
i did read the manual...but i still dont understand it.lol. and i dont feel too bad because reviews about the unit said its kinda hard to navigate but once you get used to it, its an awesome unit. when i push the multi-control button, an option for the clock doesnt come up..
Old Jan 28, 2008 | 04:38 PM
fredmr39's Avatar
Yes it does. I have the Premier DEH-P880PRS, and I compared the user manuals. They are identical for setting the clock.
The unit has to be OFF or in DEMO MODE or whatever....NOT in TUNER or CD mode.
Once off, hit the MULTI-CONTROL button. Then scroll though the options by turning the MULTI-CONTROL button counter-clockwise or clockwise until you see the clock.
There aren't as many dedicated buttons which makes it more simple to "guess", but this setup shouldn't take you long to learn.
Old Jan 28, 2008 | 05:06 PM
Gordon0652's Avatar
Would you be willing to replace your factory amp with something that has more power and is much more cleaner sounding?
