question on sub and amp
Old Feb 2, 2008 | 12:21 PM
1998_trans_am_ls1's Avatar
Default question on sub and amp
ok i should be getting subs and amp soon i really dont know what to get though i am not sure if i want two 12in or two 10in subs or how much power amp. i would want the subs and amp somthing with either black red or both, give me some ideas and how would i set these up i have t tops and they will be out when it is nice out. so is there anyway to set it up above the t top holders. so tat it does not bust the t top glass.
Old Feb 2, 2008 | 12:25 PM
3.8redbird's Avatar
Subthump T-op box
http://www.subthump.com/acamarottop.htm
and i like 2 12's
and am going with kicker for there lifetime guarentee
dont know bout amps yet
Old Feb 2, 2008 | 12:28 PM
thanks alot 3.8redbird whats everyone else say
Old Feb 2, 2008 | 12:47 PM
i need some opinons
Old Feb 2, 2008 | 01:25 PM
what is probaly the most you would want to put into a fbody amp and sub watt wise
Old Feb 2, 2008 | 02:15 PM
98boxer's Avatar
Put as much wattage as the subs ask for, just remember to get a high amp for your front speakers or else you would hear the music details at all.
I have one 12 sub and no amp for the front speakers and when i have the sub hitting hard i can't hear the voicl or detail of the music i listen too. So make sure to buy two amps, one for the subs and the other for the speakers.
Old Feb 2, 2008 | 02:17 PM
i would not need a amp with as much power for the speakers right?
Old Feb 2, 2008 | 02:28 PM
98boxer's Avatar
Say you have some Kenwood speakers 6.5 and they say 75 watt rms. I would buy an amp closet to the 75 watt rms power range or one slightly more.
Belive me you will have a lot of great sounding bass from a pair of 12 subs, but you will defently need an amp for the front speakers.
Old Feb 2, 2008 | 02:34 PM
my front speakers are stock what do you think?
Old Feb 2, 2008 | 04:39 PM
KEE AUDIO's Avatar
I have 5-channel amps that run the whole system from one amp. It is 2 amps in one. One class A/B for the front and rear channels, one class D for the sub output. I also have the installation kits for these!
Old Feb 3, 2008 | 01:21 AM
98boxer's Avatar
You're going to have to buy some good after market speakers. The stocks are not loud enough and i would imagine would blow up when used to an external amp.
Old Feb 3, 2008 | 01:22 AM
98boxer's Avatar
He could also use a Tri-Amp if he only used the amp to run 2 speakers and one sub.
