Removing OEM stereo
I've found this in the stickies above:
https://ls1tech.com/forums/showpost....1&postcount=25
Do I have to do anything before removing the stereo for security purposes? How about when I reconnect the factory stereo? Are codes required to turn the stereo back on?
I am only going to pull it off this weekend to takes measurments, Im not actually going to do any modding just yet.
You can see how I did it here maybe it'll help you out.
The Theft Lock system was not activated from the factory and most users never bothered to set up their PIN code to activate it. You can tell if it's active by whether the red LED on the face of the radio blinks when the car is off. If not then you don't have to worry about the Theft Lock. If Theft Lock is set but you don't know the PIN then all is not lost - the procedure for recovering a lost PIN is in the FAQ thread at the top of the forum.
https://ls1tech.com/forums/showpost....23&postcount=8
Thanks guys!
