KEE AUDIO - Replacing speakers
I'm not changing the head unit, because all of the aftermarket head units do not match the interior. Looks ghetto as hell.
So I just want to replace the crappy monsoon speakers.
So can I replace all my speakers?
If so what are my options? Which speakers on your site and I replace the stock ones with.
if you are wondering what speakers would be direct replacements for the monsoon speakers, read the FAQs, it should tell you what ohm speakers you need for each place
but if you replace the crappy monsoon amp with a decent one, it will open up your options quite a bit more, and wire all the speakers to it rather than having the monsoon headunit run any of them
I put together speaker packages all the time that work with the stock Monsoon system and make marked improvement in sound. My personal favorite for a nice upgrade to the speakers in a Firebird is use of the either the CDT CL-61 or CL-E61 component set in the doors and a pair of Bazooka DVC subs in the sails. These make a vast improvement over stock in sound quality and power handling. Both door and sails would be replaced and improved for around $300.00.
I read what you mentioned about aftermarket radios. What is it exactly that you think makes the install look ghetto? Is it the radio itself not matching stock illumination or just the use of the adapter kit to make it fit in the stock opening possibly? Just asking as I may be able to help find you something that would work for you. The only reason I mention it is because it really makes another improvment in sound with that upgrade. The Monsoon amp when given a clean signal to work with sounds like a completely different system with the use of a quality unit. I just wanted to put that out there to see if I can help with that as well. There are some tasteful installs for HU upgrades that can be done.
Focal is another story. They are very nice and are in the league as the CDT's.
I'm about to install CDT ES-62i comps in my doors as I have a great deal on them. I also have a set of ES-06+ for the sailpanels but will have to modify my panels again because they are cut for 8" subs. In addition to all that I have new 12' HD-SQ subs and a Phoenix Gold 5-channel amp going in as well.
The HD and ES series CDT's are as good as anything Focal makes. Overall both are excellent quality but just like any other speaker they all have unique sound properties that sets them apart from each other. Which is good because we all have different tastes in what sounds "best".
It's a few things I think make it look a little ghetto. It's the illumination, high tech future look, the adapter kit, and the **** and everything else that don't match with the car. But I have seen a few custom bezels that make some aftermarket HUs look somewhat respectable.
I will talk to you through pm KEE AUDIO
