Anyone here capable of/doing speaker repairs?
Old May 20, 2008 | 12:49 PM
Intercooler2's Avatar
Default Anyone here capable of/doing speaker repairs?
I have a set of $400 Focal CV-690 paper weight 6x9's I would like the one fixed if possible. It has a busted lead and needs attached to the frame again. Anyone here capable? See pics. Or if someone wants to make an offer the other one is good and I have the X-overs and all.
Old May 20, 2008 | 12:55 PM
Picture 2
Old May 20, 2008 | 05:39 PM
YellowToy/A's Avatar
That looks like a quike fix just get a sloding iron and solder. Heat it up and put solder on it
Old May 20, 2008 | 06:36 PM
You mean where it is busted fuse the ends together with solder? Didn't know if it would take or work. Any idea if it will work as normal with some solder on there?
Old May 21, 2008 | 08:56 AM
wssix99's Avatar
Save the manuals!
Here's a guy with a good write-up on solder splicing. You can do it, but the key is having overlap in the wires. (And not melting the stuff around your work with the iron.) The key is having overlap in the wires, so you'll need an extra piece to bridge the break.
http://jaguar.professional.org/electrics/splicing.php
There are mechanical splices, but I imagine they would weigh on the coil and impact the sound. (Soldering may even do the same.)
Old May 21, 2008 | 11:33 AM
dragonrage's Avatar
Solder will be fine. Just make sure you've got something (like the "third hand" product) to hold the wires.
Old May 21, 2008 | 04:40 PM
Snootch's Avatar
Those woven tinsel leads can be a bitch to solder. You really need to do 3 things:
1- Tin both sides to be connected- coat the wires on both ends with solder, Just enough to change the copper color of the leasd to silver at the ends, not a blob of solder.
2- You will need to use a heatsink (alligator clip with a wafer of metal attached to it) clipped to the side closest to the cone. This needs to be done so the heat from the soldering iron doesn't burn the voice coil or voice coil former.
3- Clean the copper wire well with alcohol before soldering, and use some rosin on it before tinning the wire. Otherwise the solder may not stick to the wire.
I have tried this a few times and it only worked one time. If you end up with a blob of solder on the connection it will slap against the cone causing a rattling sound and eventually fail. So remember with soldering, less solder is better!
Old May 21, 2008 | 05:48 PM
dragonrage's Avatar
You can put some heat shrink over it after if you want
