Dissapointed in the DBs
I am currently in Daytona beach lookingm for apartments so downloading is not possible, but when I get home I will for sure get to downloading.
Oh no! Do some research. I placed an order through E-Bay to try FatMat and they cancelled a paid for order on me without my consent. I gave them their first negative over it then they tried to blackmail me to remove it. I later read that is basically no different than Peal and Seal you can get at Lowes. It is asphalt/butyl based but not the good butyl like Second Skin. That's what I bought and love it.
didn't want to read through the whole thread but, yes roll up the windows you will see quite a bit of gain in db's. why do you think in competitions the windows are usually rolled all the way up or one is cracked slightly?
I know what sounddeadner is ive been in the car audio game for a number of years and used many diff products. But you arent gonna gain 3 db from one layer much less 7-8 from 2 layers or whatever you said earlier.
. i have it running off of a fosgate 25 to life punch 150. the box is tuned kinda low @ 29Hz. but it still hits really hard. i could blow the sub pretty easy considering how underrated the amp is. A couple things.
1.) WE do not hear in a linear form.
2.) Sound pressure is measured in dB. 3dB is a doubling of output power. It takes either a doubling of cone area or a double in power to acheive a 3dB gain. To gain another 3dB, you would have to double what you already doubled. So 10dB takes ALOT of power or cone are increase to acheive this. Or an extremely efficently tuned enclosure that usually are 1 note jugs.
3.) No dynamat or similar substance is going to net you 3dB in your car unless you hit some magical node frequency.
4.) Ported is much more efficient then sealed, but takes up more room and needs more airspace.
5.) Look into poly-fill if you haven't added it yet. It won't make that big of a difference, but it can help a little.
Here's some old info I typed up a couple years ago. It's in this thread.
https://ls1tech.com/forums/wiring-stereo-electronics/271152-quick-electronic-theory-ya.html
Pioneer did a study in what was once their new testing facility on the affect of distortion and SPL to the human ear. The results were interesting. The reason for this is because measurements are linear, straight line, our ears hear in a non-linear fashion.
SPL is usually measure in dB's. Deci-Bell's. It's a measurement of the Sound Pressure Level. It usually expressed in #'s like this 121dB. Now the absolute #'s are really arbitrary. A persons experience will say what is louder. What follows is mostly true for Subs. Mids and highs are different.
Now dB's do correspond or relate to power. For a 3dB increase you need either a doubling of power or a doubling in cone'age area.
(I.e. To get 3 dB increase you would need to go from 1 12" 500 watts to either 2 12" 500 watts total or 1 12" 1000watts total.) or (2 15" 1000watts. Needs 4 15" 1000watts or 2 15" 2000watts.) 3 dB would seem to be twice as loud right???
Actually no. When Pioneer and others tested this, they found that the average person need ~10dB in order to perceive sound as being "twice as loud" to get a 10 dB increase takes a lot of power and lots of speakers. The least amount of increase for a person to notice a change is about 1 dB. Average amount to hear a change is 3dB.
i.e. System with 1 12" sub 100watts. 10 dB increase, you would need 10-11 12" speakers or ~1100 watts of power. For every 3 dB double what was before. 1-2, 2-4, 4-8, 8-16. 100-200W, 200-400W, 400-800W, 800-1100W.
Let me 1st say that distortion is the #1 killer of speakers. It causes the speaker to move in irregular motions and warps the cone and puts the driver out of alignment.
For distortion they fed test music with distortion embedded in it. starting at 0.5%. By 1-1.5% most listeners noticed the distortion coming from the tweeters. By 2%-6% most listeners noticed it coming from the midrange speakers. By 6%-9% most listeners noticed it coming from the Midbass drivers.
And from 10% (very few people heard it) to 20% distortion is when most listeners heard it coming from the subs. The ears may be the best test equipment you own but have limitations.
