Security light comes on and car won't start?! HELP!
There are 2 ways of going about it.
1) Get another key from the dealer. The key alone is going to cost you $50. If they can make one of your current key. If not you'll have to buy the cylinder as well, they come with the template key. I priced it about a month ago the whole thin should run you about $160.
2) Bypass vats with use of resistors. Take your key to the locksmith and have it tested. If the car still start it should give you the right code. The using this code reference it form the table bellow. The the maching resistors (make a chain if you have to). Find your vats cylinder cable. It is comming off you r steering column cylinder. It is alway orange with too white wires inside. Cut it off and attach your resistors to both wires. Make sure you attach it to the wire that goes in to the dashboard. This will permimently bypass your VATS. And will cost you about 20 bucks.
Here is teh resistance table: http://www.thirdgen.org/tech/images/...tanceTable.jpg
I would look around some hardware stores before you go to the dealer.
to all especially Johnny for the help. Got her starting again.
