6x9s in the trunk?
6x9s in the trunk?
what would it take to make 6x9s fit in the 2 spots in the trunk? the previous owner was a dumbshit and one speaker is missing and the other ones disconnected and the wire to hook it up in no where in sight so...im going to be replacing all the speakers in my car with some nice stuff and want to fit some 6x9s in the back.
https://ls1tech.com/forums/wiring-stereo-electronics/941537-could-one-fit-6x9-s-rear.html
I asked the same thing. Prepare to get raped on oval speakers being inferior sound quality.
Here are some pics of what I did. You can see the screws peeking out a little bit from under the grill. I had to cut off some of the tabs that hold the grill on, and trim it a bit to let the screwheads fit, but I think it came out OK. Those are just some basic Pioneer 2 way 6x8 speakers but they sound pretty good. Driven with the stock 2-ohm amp, but even with the mismatched 2-ohm 4-ohm setup it does pretty well. I used the stock plug from the old speakers so that the panel is easy to remove totally if needed and keeps from hacking up the original wiring too much.
It looks like there is room for 6x9 perhaps. I used the 6x8 because that is what had already.
