10 Second Club Now you are haulin! 10s are sweet
Any 383 ls's in the 10s??
Old 04-01-2013, 03:53 PM
SStressin's Avatar
Default Any 383 ls's in the 10s??
wondering what you guys with 383 ls1s are running? im on my quest for 10s this season
my setup is a 383 ls m6 in a 00 camaro ss.
race weight is around 3400 with me in it.
full umi suspension
skinnys n slicks
9 inch with 4.30s
11.6 to 1 compression
cnc trickflow 225s
ported fast 92/92
texas speed 1 7/8 lts thru cutout
full boltons
and big custom spec eps cam 240/256 .647/.647 111lsa
wondering what fully done 383s will do havent really seen to many of them posted on here there 1/4 times
Old 04-01-2013, 05:02 PM
big dave's Avatar
Though I don't have a 383, I see no reason why you can't reach your goals. It sounds like a pretty stout setup. If your cam matches up well with your heads, 10s should be in the bag especially at a 3400 lb raceweight.
Old 04-01-2013, 08:06 PM
N2RACINGLS1's's Avatar
If you can get it to 60 foot in the 1.40's with you setup it should break 10's easy. Good luck!
N2
Old 04-02-2013, 08:17 AM
ls1curt's Avatar
383 ls1, 11.4 comp, prc 5.3 heads, 243/251 .623/.623 111lsa cam, fast 92mm, th400, 3450 raceweight. ran 10.4@129 and made 427rwhp.
The following users liked this post:
Troy Mcquillan (12-10-2020)
Old 04-02-2013, 05:22 PM
BayAreaSS's Avatar
It better run 10s lol
Old 04-03-2013, 03:22 PM
deerslayinrednek's Avatar
I assume you ran N20 to run times in your sig.....If you dont mind me asking, what shot was that with?
Old 04-04-2013, 07:56 AM
ls1curt's Avatar
The times in my sig are with the same 383, but with different heads and cam and a turbo. I did end up going 10.0 @ 134 on a 100 shot though.
Old 04-04-2013, 09:07 AM
Roarin_8's Avatar
IIRC reason being why you don't see too many 383 setups is because of the price, usually guys go with 402s or 408s for around the same price as a 383 setup.
Old 04-04-2013, 10:49 AM
blackls1ta00's Avatar
i made the mistake of doing a 383 but now doing a 408 wish i would have done this 408 before
Old 04-04-2013, 01:50 PM
Troy5061's Avatar
My 383 N/A last year ran a 7.26 in the 1/8th mile with a stock ls6 intake/TB and stock 243 heads. That equals about an 11.3 in the 1/4. Should be able to hit 10s on motor with the PRC heads, Fast intake, 90mm TB and bigger cam. I know I could get there with a bigger converter and an aftermarket torque arm easily. btw my 60fts were consistent 1.56-1.58s with the stock torque arm.
Old 04-04-2013, 08:26 PM
I'm currently at that crossroads LS1 383, LQ4 408, or LS3.......Too many options
Old 04-19-2013, 02:53 PM
dstappity's Avatar
A friend of mine has an almost stock camaro running 7.0's all day long in the 1/8 which I believe converts to the 10 second range in the 1/4
Car is a Stock 02 ls1 z28, upgraded to ls6 intake, ls6 cam on stock 241 heads and ls6 valvesprings, long tubes, nitrous converter and a 100 dry shot. Car only has bilstein shocks and running a 265 radial. 1.5 60'.
If he can do that pretty much stock, I don't see why a freaking 383 wouldn't, lol.
Old 04-19-2013, 05:34 PM
Roarin_8's Avatar
Stock 2002 Z28 should already have an ls6 intake.
Old 04-19-2013, 08:08 PM
dstappity's Avatar
Might be an 01 then, I know he had the ls6 intake installed
Old 04-19-2013, 11:05 PM
Roarin_8's Avatar
Has to be earlier, 01-02 had the ls6 intake, 98-00 didn't. Also the 98-2000 had the EGR as well and the LS6 intakes didn't have that.
Old 10-16-2013, 05:33 PM
6SSPEED's Avatar
What is almost stock about a set of long tubes, a converter, cam and nitrous???
Old 10-17-2013, 09:32 AM
BayAreaSS's Avatar
my thoughts exactly. In that case people are running 9s almost stock lol
Old 04-30-2014, 11:07 AM
VandykeT/A's Avatar
My SBE went 10.92 @ 126 with a stick and I'm sure I was heavier than you. That was at almost 2000 feet. You should be there.
Old 06-26-2014, 03:35 AM
blk496ss's Avatar
My 383 went 10.4 on a 100 pill
Hogged out 853s lol
Victor jr intake
90mm tb
Th400
10bolt 3:73
Full bmr rear suspension
Old 11-26-2014, 06:01 PM
Hot_Wheels's Avatar
382 auto N/A
Quick Reply: Any 383 ls's in the 10s??
