Sponsored by: DashLynx
need some help with dash gauges
Old 05-01-2010, 07:01 PM
LILWS6's Avatar
Default need some help with dash gauges
I've been toying with the idea of yanking the a/c out of my car just for the fact that i don't ever use it any way and i mean all of the a/c not just the compressor. so since i need the dash to come out i was thinking the cleanest gauges ive seen mounted are in the air vents. in the middle they look good right in place and easy to read. Now i'm looking for some more info on how exactly to go about completing this gauge project? i have to figure out what gauges i want as well but i believe i've seen adapters that fit in there to make 2 1/16" gauges fit nicely any help maybe some pics for me? what did you do with the heater vents or did you just leave them functional? what gauges did you go with. the car is a 6 speed so i really doin't need a trans temp. getting a 12 bolt going in a few weeks here just had one ordered yesterday. next week i'm ordering up my drive shaft so i'm going to have some spare time to tinker thanks in advance
Old 05-01-2010, 10:26 PM
YURVIEW's Avatar
Here's your link for how to make the adaptor. I did this as well, works Perfect!!
https://ls1tech.com/forums/appearanc...cheap-way.html
As for the removing the A/C, you on your own. lol I NEED mine!!!! I'll just stay slow.
Old 05-02-2010, 08:05 AM
LILWS6's Avatar
i won't need any help on the a/c part i ment what did you do witht he ductig that goes to where the vents used to be now where the guages are or did you just leave them atached? got any pictures of your setup? thanks for the link
Old 05-02-2010, 09:46 AM
Tally TransAm's Avatar
2 5/8" gauges fit perfect, the 2 1/16" need an adapter
i just left the ducting because i still kept the heater
Old 05-02-2010, 11:32 AM
YURVIEW's Avatar
I'd leave the ducting. Too much of a pain to remove entire dash Just to remove 2-3 lbs of plastic. I just drilled a hole In the ducting big enough to run wires thru.
Here is link to thread with pics of my setup.
https://ls1tech.com/forums/appearanc...ew-access.html
Old 05-02-2010, 05:22 PM
LILWS6's Avatar
i figured i'm going to have the dash out of the car any way so i might just have to see how hard it is to remove if its easy as pulling them out i'll go that way but you guys arn't haveing any issues with them still there are you?
Old 05-02-2010, 05:23 PM
LILWS6's Avatar
reason i wanted to go 2 1/16" is don't they make adapters that kind of angle them toward the drivers area a little bit? thats what i'm looking for
Old 05-02-2010, 05:56 PM
Spd-Kilz's Avatar
I've done it. Don't expect to ever use the top vent setting.
I'd suggest:
-Oil Temp
-Wideband
-Aeroforce Interceptor
I drilled the plastic behind the gauge to pass the wires. Powered them from the radio, and light them up from the parking lights. I thenstuffed behind the gauges with foam.
I'm using 2 5/8".
Old 05-02-2010, 06:12 PM
LILWS6's Avatar
what wide band is recomended? also what exactly can the Aeroforce gauge do besides codes?
Old 05-02-2010, 06:52 PM
not sure about the angled adapters, but i dont think you need them as there is ZERO issue on visibility
Old 05-02-2010, 07:02 PM
Spd-Kilz's Avatar
I'm not sure what one to recommend, but I know not to use the AEM. I couldn't get it to work with my HP Tuners.
The aeroforce gauge will display any information that the computer reads (O2 mV, MAP, IAT, coolant temp, knock retard, timing etc etc). Also gives you MPG, and 1/4 mile times.
Old 05-02-2010, 07:11 PM
LILWS6's Avatar
seems like the best overall gauge for the money may have to look into that. i might end up doing these gauges one at a time. going to get expensive
Old 05-02-2010, 07:15 PM
Spd-Kilz's Avatar
You're not kidding.
I've had good luck on Ebay with the Autometer ones. I managed to get all of them (new) for about half price.
Quick Reply: need some help with dash gauges
