Sponsored by: DashLynx
Camaro guys - better, brighter fog light bulb available
Old 10-15-2010, 10:01 PM
SparkyJJO's Avatar
Default Camaro guys - better, brighter fog light bulb available
Put simply, the stock 37W bulbs really don't do a whole lot in the Camaro fog lights. Many go with HIDs, but some have had issues with some of the 880 HID bulbs not wanting to fit the housings due to bulb length.
The 98+ Camaro projector fogs are mostly metal and glass, so there really isn't a risk of melting anything. I looked at all the various 880-based bulbs and found the 886 - 50W instead of 37W. Cheaper than an HID kit, no risk of the bulb being too long, so heck I figured I'd try it.
They are actually noticeable when I turned them on. Sweet!
I checked the housings after using them for a couple months, just to be sure, and there was no signs of heat damage whatsoever.
Just an FYI to you guys looking for something brighter but not sure about going to HIDs
Oh, firebird guys, I don't suggest you try this - I've read the birds use plastic housings/lenses and those would melt with the added heat output.
The following users liked this post:
fucter (10-03-2021)
Old 10-15-2010, 10:20 PM
Alex41's Avatar
Great write up. Where can I find these bulbs; parts stores?
Old 10-15-2010, 11:10 PM
SparkyJJO's Avatar
Yeah I found mine at Advance Auto.
Oh, and regardless of which bulb you do end up getting, DON'T get any with the gray "cap" on the top. It just cuts down on light output for us. The Firebird guys should use the capped ones because of glare from the hotspot of the bulb, but since the Camaro has projectors all the cap does is reduce light output out the top and makes a dark spot on the projector bowl.
Old 10-16-2010, 01:11 AM
bad_408_vert's Avatar
always good info!
Thanks Sparky!
Old 10-16-2010, 04:58 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You got a part number?
Old 10-16-2010, 10:17 AM
SparkyJJO's Avatar
The bulb number is 886.
Old 10-16-2010, 07:26 PM
Z28/2002's Avatar
thanks
Old 10-16-2010, 09:33 PM
camarox302's Avatar
Any before or after pics?
Old 10-17-2010, 02:52 AM
99'CajunFirehawk157's Avatar
FWIW, they say pre 98 firebird fogs were glass and are a direct replacement for 99-2002, FWIW
PS-I put leds in mine because I do very little night driving and they tied in nicely w/my other 6k leds.
Old 10-17-2010, 03:56 PM
01SOMSS!'s Avatar
how much are the bulbs?
Old 10-19-2010, 05:09 PM
chrysler kid's Avatar
they are $6.99 at oreilleys and they are barely brighter. dont bother unless you have a bulb burn out i still cant even tell they are on at night
Old 10-27-2010, 03:29 PM
Ls1CamaroGuy87's Avatar
Pics please
Old 10-27-2010, 09:12 PM
SparkyJJO's Avatar
Maybe yours weren't aimed right. OR it is because of HIDs in your reflector housings throwing light all over drowning them out
Originally Posted by Ls1CamaroGuy87
Pics please
I can't. Car was wrecked last month, sold the fog lights.... I just posted this after the fact after I remembered I had done this when I pulled them out of the car to sell the housings. Had waited because I wanted to be sure the 50W wasn't going to damage the housings, which it didn't. Didn't think it would, being all metal and glass, but wanted to be sure.
Old 10-28-2010, 12:08 PM
they are aimed as high as they can go, even driving with the headlights off and fogs on i would be better off with a mag light
blah
Attached Thumbnails Camaro guys - better, brighter fog light bulb available-meetmonday.jpg
Quick Reply: Camaro guys - better, brighter fog light bulb available
