Sponsored by: DashLynx
Tape residue on window
Old 04-06-2004, 12:32 PM
99BackNBlackZ28's Avatar
Default Tape residue on window
I've had a temporary sticker in my back hatch window on the T/A for about 2 weeks...anyhow, I got my plates today, and low n behold when I pull the temp sticker off the tape (duct) left a residue. What's a good way to get the residue off? The window is tinted so I don't want to use anything that will destory the tint. Any suggestions would be appreciated.
Old 04-06-2004, 01:56 PM
KCamaro's Avatar
carefully use a razorblade to scrape it off especially if it is on a tinted surface.
Old 04-06-2004, 02:14 PM
Ling_650vette's Avatar
If its on a tinted surface you're better off using something other than a razor blade unless you're REALLY careful. Try not to use anything really harsh either, or it may mess up the tint.
I say try your best to use some kind of glass cleaner, let it soak into the residue a bit then if you're REALLY REALLY careful use the blade. When we had to remove stickers off the tinted window cars, a lot of time it would come off just by scrubbing it after lettin the solution soak in a bit.
Old 04-06-2004, 03:07 PM
01ws6bird's Avatar
goo-gone..
Old 04-06-2004, 06:33 PM
I have goo-gone, just afraid that it'd be too harsh and end up eating the tint.
Old 04-07-2004, 07:42 AM
Brandon_TA's Avatar
I have ALWAYS used fingernail polish remover to remover sticker/tape film... not mine of course.
I have never used it on tint though... I'd suggest just being patient and using some elbow grease and a wet rag.... I wouldnt risk messing up the tint.
Old 04-07-2004, 09:19 AM
Moderator
jimmyblue's Avatar
WD-40, let it sit for a bit and then work it off
with a paper towel. Gentle, chemically, but pretty
effective.
Old 04-07-2004, 09:46 AM
Brandon Boomhauer's Avatar
aklyhol
DONT use a razor, hell windex or Stoners glass cleaner will work.
Plastic razor would work, but good luck finding them (and if you do let me know where at)
Old 04-07-2004, 11:41 AM
Mark IXZD 150's Avatar
I would think that any of those citrus based goo removers would be fine.
Old 04-07-2004, 12:24 PM
PNY ETR's Avatar
Goo gone has worked on my car before... I used a plastic scrapper and some goo gone!
Old 04-08-2004, 04:12 PM
SuperDave479's Avatar
Yeah I'd say WD-40 or an ammonia-free window cleaner. Windex is not ammonia-free. Ammonia makes your tint turn purple.
Quick Reply: Tape residue on window
