Sponsored by: DashLynx
TypeX halo fog light Conversion
Old 04-10-2013, 11:47 PM
neverlift17's Avatar
Default TypeX halo fog light Conversion
I am wanting to change the fog lights to halos, im not sure of the diameter but the bumper is a 2000 formula.
Will these fit and work or do I need a different set and how hard is it to convert?
any tips or advice will be appreciated thanks
Attached Thumbnails TypeX halo fog light Conversion-20130410_225017.jpg   TypeX halo fog light Conversion-20130410_231403.jpg   TypeX halo fog light Conversion-20130410_225707.jpg
Old 04-11-2013, 01:05 PM
CALL911's Avatar
PM replied to. In short, "no", those will not work.
To my knowledge there is no "kit" offering an aftermarket halo fog light for our cars. I had to custom make mine. It was not easy to do, but then again it wasn't rocket science either. If you are looking for something plug and play simple, it doesn't exist, and if that's what you are looking for, you are better off just stopping there. It can be done though if you are willing to spend the time and money to do it on your own though.
Old 04-11-2013, 01:29 PM
2001WS6-DJP's Avatar
There is a company that makes them. I will try to find them and get back with you.
Old 04-11-2013, 02:00 PM
Thanks, I am not to worriad about the install I just want to make sure I have the right ones that will work.
Is this the company you are talking about?
http://www.blinglights.org/products/...-LAMP-KIT.html
Old 04-11-2013, 04:28 PM
Copy & Paste Moderator
VIP1's Avatar
Those Bling Lights don't look worth $90. I've seen stuff like that on the shelf at Pep Boys for $40.
Take a look at the Lighting FAQ to see what others has installed.
https://ls1tech.com/forums/appearanc...hting-faq.html
Old 04-11-2013, 05:01 PM
Daniel Richards's Avatar
Everyone has missed the main point, those shown in the OP are roughly a 3" diameter and the stock fogs are a 4.5" diameter.
Old 04-11-2013, 06:44 PM
CALL911's Avatar
I brought this up to the OP in a PM that correct measurements needed to be made. This was after I told him they would not work.
Old 04-11-2013, 08:30 PM
Streetlegal?'s Avatar
OP has a formula not a TA. The stock TA fogs are 4.5". Formys are 3.5" (I think)
Old 04-11-2013, 08:37 PM
I measured earlier today before work, the Firebird/Formula front bumper is a 4.5" fog, now from what I remember the DRL/turns are about 3.5", either way the lights in the OP say 75mm and with 1 inch equaling 25.4mm that puts the ones in the OP just under 3 inches which is to small either way..
Old 04-11-2013, 09:01 PM
CALL911's Avatar
In either event, the exact measurement needs to be made to find the appropriate lamp size.
Look this isn't that difficult. Take a good measurement, then find the lamp you want that is the right size. I went with a higher quality Hella lamp http://www.rallylights.com/detail.aspx?ID=128
You could also get cheap $40 a pair ones from eBay.
Then I bought eBay halo rings that measured up perfectly to go around the projectors I got. I went cheap and silicone the rings to the projectors. That was years ago, and they still are working perfect. I even went with some DDM tuning HID's for the projectors.
I probably have about $200 total in mine. It was not anything cosmic. The hardest was making the brackets. But its still fairly simple fabrication. It takes time on your own part, and a little self engineering, but I think most could probably mimick something similar.
Old 04-11-2013, 10:29 PM
VIP1's Avatar
The Formula & T/A Fog Lights are the same size around 4.5".
Old 04-12-2013, 02:48 AM
it took some digging but I found the thread http://www.fullthrottlev6.com/forums...in-98-Firebird aftermarket fog lights with the Halo ring that are the right diameter (despite him giving the wrong size in the post) that are a relatively easy install in place of the stock lights.
Old 04-12-2013, 08:54 AM
CALL911's Avatar
FWIW, that one is WAY harder to do than what I did (I did not have to splice any wires). So you've got options.
Old 04-12-2013, 10:14 AM
VIP1's Avatar
You didn't have to dig if you went to the Lighting FAQ I posted above.
Here is the LS1 Tech version of that thread:
https://ls1tech.com/forums/appearanc...8-formula.html
Its a copy-and paste of the Full Throttle V6 post.
That link is posted in the Lighting FAQ.
I just added your link to the list as well.
I did that mod too. A link to my setup is in the Lighting FAQ as well.
Those fog lights aren't that great. They have a conical beam pattern instead of a low & flat beam pattern. So basically, they are flood lights and not fog lights. I usually leave them off.
Quick Reply: TypeX halo fog light Conversion
