Sponsored by: DashLynx
god for-saken water spots
Old 08-29-2006, 10:25 PM
1sloLS1's Avatar
Default god for-saken water spots
ive got these damn water spots on hatch glass and both windows and t-tops that i cant get off. please someone help i have tried everything short of battery acid!!!!!
Old 08-29-2006, 10:28 PM
RUNINHOT's Avatar
steel wool+vinager water mixed together+4hrs of scrubbing
Old 08-29-2006, 10:33 PM
Xx01CamaroZ28xX's Avatar
Are you serious, because I have the same problem.
Old 08-29-2006, 10:39 PM
RUNINHOT's Avatar
It works best with 00 steel wool. You can remove the spots off of the tops, front, back, side, and mirrors. There was a thread about it already
Heres some more info on it
https://ls1tech.com/forums/search.php?searchid=3846266
Old 08-29-2006, 11:07 PM
LFNDUST's Avatar
don't use the steal wool on the paint please...
Old 08-29-2006, 11:14 PM
LS1MONSTER's Avatar
Claybar or a good paint cleaner should fix you right up.
Old 08-29-2006, 11:22 PM
TUMBLRws6's Avatar
I HAVE THE ANSWER!!!!!!! Eagle One Never Dull....buy at walmart! its in a silver tin can! THIS WORKS BEST to my knowladge...and iv tried everything! Im a carshow FANATIC and it gets my GLASS (not paint) looking like new! works amazingly on chrome rims as well
Old 08-29-2006, 11:28 PM
Camaro Ryder KV's Avatar
lighter fluid, takes 5 min per t-top and about 10 min for hatch.........then just go over it with a spray detailer takes a total of like 25 min, worked 110% for me!
Old 08-30-2006, 07:24 AM
1sloLS1's Avatar
i will have to try these techniques thanks guys
Old 08-30-2006, 07:33 AM
chupr0kabra's Avatar
https://ls1tech.com/forums/appearance-detailing/567489-removing-hard-water-streaks.html
-Mike
Old 08-30-2006, 09:14 AM
11 Bravo's Avatar
I had the waterspots from hell on my windsheild. Tried vinegar and all kinds of crap. I remembered that toothpaste polished up the plastic tailights good. So I tried it. Worked awesome, the spots are all gone. Just spread some on with your fingers, spray it with glass cleaner to thin it out and start rubbing it in with a cloth. When you wipe it off the spots will be gone. Didn't work on the paint lol
Old 08-30-2006, 09:59 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Take a rag and soak it in the vinegar mix and then lay it on the spots with the water spots. Let them sit for 5-10 minutes so it can dissolve the dried mineral deposits which is what water stains are.
You can also use a dilute mixture of CLR (calcium, lime, rust) and do the same thing. Just make sure you are careful around the paint.
I always treat my glass the same way I do my paint. It gets claybar'd, polished and waxed just like the paint.
Old 08-30-2006, 11:28 AM
Blk00TransAm's Avatar
Actually i tried a window cleaner called invisble glass. it took all waterspots off. looks tike the new windshield i put in.
Old 08-30-2006, 12:20 PM
1sloLS1's Avatar
these spots are so bad the have almost a purplish tint to them.
Old 08-30-2006, 12:26 PM
99_Z_155's Avatar
will this work for me, i have some primer overspray spots on my t-tops. i tried a very light rough side of a sponge, and it SCRATCHED the glass. im thinkging steel wool would be even worse...
Old 08-30-2006, 01:19 PM
UNDER PRESSURE MOD
If you use steel wool, use the quad 0 (0000) since it is the finest grade of steel wool. It won't scratch the glass but will remove most everything. Think of it as 4000 grit sandpaper.
Old 09-01-2006, 01:42 AM
mrws6speed's Avatar
If you want to know how to get water spots out of glass...read my postings from this thread. A-MAZ is what will take them out....no problem....it will work like nothing you've ever seen!
https://ls1tech.com/forums/appearance-detailing/470854-help-water-spots.html
Old 09-01-2006, 06:24 AM
pjb
pjb's Avatar
keep us informed with your results.
Old 09-01-2006, 07:34 AM
_JB_'s Avatar
Try Zanio glass polish, worked really good for me.
Old 09-01-2006, 08:34 AM
pjb
pjb's Avatar
give more detail.
how did you apply it.
sorry for same questions in a related thread. just looking for details.
