th400 swap now it won't start
Old 11-14-2009, 02:08 PM
98Camarod's Avatar
Default th400 swap now it won't start
I'm attributing this to not having the shifter harness wired up. I'm assuming it's due to the neutral safety switch not being wired up. Can someone tell me how to bypass this for the time being? I'll also need to know how to properly fix the problem so I can be safe of course. I have a b&m pro ratchet shifter which doesn't have the neutral safety switch on it.
Old 11-14-2009, 02:54 PM
trans2000am's Avatar
got put 2 wires together they have it posted in the sticky page on th400,i had the same issues just jumped the wires and bang started up.
Old 11-14-2009, 04:18 PM
98Camarod's Avatar
Yeah I have a new issue now. Either the b&m ratchet shifter is no good or I'm missing 3rd gear
Old 11-14-2009, 04:43 PM
so are you trying to hook up the wires that come from the b&m shifter to the stock harness from the old shifter? my hurst pistol grip had 2 wires but i didnt use them just connected the 2 wires from the stock harness together just gotta make sure your in park before you start the car... i had an issue getting my car into first all the way and come to find out the hurst pistol grip comes ready for a glide so i had to remove this piece that wouldnt allow the shifter to go all the way back. thats what i get for not reading the instructions lol
Old 11-14-2009, 04:48 PM
Krazy98Z28's Avatar
yes check your shifter, some come setup for a powerglide and you have to convert it to a 3 speed, did you find the 2 wires under the steering colun to jump?
Old 11-14-2009, 04:59 PM
the wires that you have to put together is from the stock shifter harness in your center console.
Old 11-14-2009, 11:22 PM
pozesd99''s Avatar
mine came ready for 4 gears....
Old 11-14-2009, 11:23 PM
Restricted User
1BAD_LS1's Avatar
LOL i had the same problem!! ready the sticky and got it started...
ya deffienetly check the plates in the shifter to make sure its not setup for a powerglide (like stated above)
Old 11-15-2009, 08:54 AM
98Camarod's Avatar
I have it running and driving. It only goes into to two gears, but it ratchets for all the gears.
Old 11-15-2009, 09:28 AM
you gotta adjust the shifter then, read the instructions its prolly set up for a glide, i had to remove the little tab on my hurst pistol grip to let it ingage into first.
Old 11-15-2009, 09:42 AM
98Camarod's Avatar
It's a rmvb gated shifter and the pin is in the correct hole for the 3 speed. It says it's supposed to be in the upper hole, which is where it is. I'm going to try and adjust the shifter cable and see if that gets me where I'm supposed to be
Old 12-27-2011, 02:14 PM
LSjim's Avatar
make sure you also have the washer
Old 12-27-2011, 03:44 PM
MUSTANGBRKR02's Avatar
2 year old thread...I'm pretty sure he got it or has given up already.
Quick Reply: th400 swap now it won't start
