fuel line hoses, enough strong to run as coolant lines?
I really cant see where it would be a problem but im not sure if fuel lines are braided properly like hydraulic lines. The auto parts stores should be able to make you a couple of lines with ends on them for about $50. I believe the 4L60e coolant lines use a 1/4" NPT fitting.
LS1TECH & Trucks Sponsor
I wouldn't do it, I've seen them blow off too easily in the past. Parts stores have the hose you need CHEAP
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Moderator
I ran around with fuel line hose on the cooler lines for
years. Only problems I had were, the hose eventually
hardens up and will slide off and puke the juice all over
the pavement. Solved that one by using 2 hose clamps
per end. But then, this was on a $499 beater vehicle.
But I would minimize the rubber and maximize the steel
just on general principles. Steel is not hard to bend to
the right fit, and no more expensive than fuel hose.
