4l60e AN transmission fittings
i want to make braided lines for my transmission cooler and route the in to the fender, so they are out of the way
so what i adapter will i need to go from the transmission to -6 line ?
some say i will need 1/4npt to -6, is that right ?
also what sort of pressure will those lines see ?
Do not buy 1/4 npt, thats not the same kind of thread the trans has cut in it. Buy a correct fitting like this: 1/4 NPS straight cut threads.
http://cgi.ebay.com/ebaymotors/8-tra...Q5fCarQ5fParts
Both NPT and NPS have the same thread angle, shape, and pitch. However, NPT threads are tapered and NPS threads are straight.
Which one to use is argued millions time over, Both work. I am using NPT in mine and have been for a while, no problems.
But they are actually NPS.
Found this picture, NPT on the left screwing into a NPS connector, NPS on the right... both screwed in hand tight, equal resistance. you can see the difference, but its up to you.
The following users liked this post:
n2xlr8n66 (03-04-2022)
This should help you. If you have any questions let me know.
Hope nobody minds me posting another forum?
http://www.ls1gto.com/forums/showthr...=hose+fittings
if a rubber line is rubbing on something it will get punctured eventually and tranny fluid is flammable. if ss braided line is rubbing on something, most likely will eat what ever it is rubbing on
How much line should I order? It looks like Summit has everything you need. I am getting 2 straight adapters with 45 degree swivel hose ends. I thought 10 feet of braided line should be enought.
Part #PriceQtyTotal
Earl s Performance 804606ERL - Earl's Performance Swivel-Seal Hose Ends
View Image and Compare
Fitting, Hose End, Swivel-Seal, 45 Degree, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue, Each
Part Number: EAR-804606ERL
Transaction
• $16.95
• $67.80
• Remove
Earl s Performance 961946ERL - Earl's Performance AN to NPT Adapter Fittings
Fitting, Power Steering, Inverted Flare, Tube, - 6 AN, 1/2 NPT, Steel, Zinc Plated, Each
Part Number: EAR-961946ERL
Transaction
• $8.95
• $17.90
• Remove
Earl s Performance 981606ERL - Earl's Performance AN to NPT Adapter Fittings
Fitting, Straight, -6 AN Male to 1/4 in. NPT Male, Aluminum, Blue Anodized, Each
Part Number: EAR-981606ERL
Transaction
• $2.95
• $5.90
• Remove
Summit Racing SUM-230610 - Summit Racing® Stainless Steel Hose
Hose, Braided Stainless Steel, -6 AN, 10 ft. Length, Each
Part Number: SUM-230610
Transaction
• $39.95
• $39.95
• Remove
Summit Racing SUM-900106 - Summit Racing® AN Line Wrenches
AN Wrench, Aluminum, Anodized, -6 AN, Each
Part Number: SUM-900106
Transaction
• $9.95
• $9.95
• Remove
Part Subtotal $141.50
Bill
Part #PriceQtyTotal
Transaction
• $16.95
• $67.80
• Remove
Transaction
• $8.95
• $17.90
• Remove
Transaction
• $2.95
• $5.90
• Remove
Transaction
• $39.95
• $39.95
• Remove
Transaction
• $9.95
• $9.95
• Remove
Bill
Part #PriceQtyTotal
Transaction
• $16.95
• $67.80
• Remove
Transaction
• $8.95
• $17.90
• Remove
Transaction
• $2.95
• $5.90
• Remove
Transaction
• $39.95
• $39.95
• Remove
Transaction
• $9.95
• $9.95
• Remove
Bill
Part #PriceQtyTotal
Transaction
• $16.95
• $67.80
• Remove
Transaction
• $8.95
• $17.90
• Remove
Transaction
• $2.95
• $5.90
• Remove
Transaction
• $39.95
• $39.95
• Remove
Transaction
• $9.95
• $9.95
• Remove
Bill
Bill
