Trans Cooler Location
So, I have this cooler..
http://www.summitracing.com/parts/der-13900
Mounted like so,
Would it hurt and or, could I run another cooler in series with this guy? Or, do you guys think its up to the task?
Mounted like so,
Gonna buy this guy and attempt to mount up front.
http://www.summitracing.com/parts/bmm-70274/overview/
So I run the coolers in series or in parallel?
I'm running a hayden 679 in front of the a/c condenser and bypassing the radiator. The highest temps I have seen from my 60e sensor that is installed in the pan is 160. And that was only after my converter kept unlocking at interstate speeds. I normally don't run over 140 so long as I am reaching lockup speeds. Stop and go will sometime get it up to 150 or so until I get back to cruising speeds.
My old stock 60e used to run the temps you said, which is why I am concerned with the current temps
Just a couple seconds of searching turns up this thread from a couple months ago which has similar sentiments.
https://ls1tech.com/forums/automatic...ilt-4l80e.html
