4L80e pan gasket?
Old 09-18-2014, 09:35 PM
6togo's Avatar
Default 4L80e pan gasket?
I just dropped the pan on my 4L80 that has almost no miles so I can have it powder coated. It has a metal reinforced gasket very nice looking compared to the cheap cork ones the question is are they reusable?
Old 09-19-2014, 05:47 AM
forcd ind's Avatar
if its the fact. style GM one, I have reused one several times w/o leakage
trick is to torq it to the proper range
Old 09-19-2014, 09:25 AM
NorthTexasConverter's Avatar
Definitely re-usable and in fact if yours is in good condition I would recommend using it over a cork or even a fiber pan gasket.
Old 09-19-2014, 10:36 AM
Closed ex-Sponsor Account
TASCAPARTS's Avatar
Just in case you cant reuse it here is the newest number
8677743
Chris
Old 09-19-2014, 10:44 AM
8677743
Chris
Hey brother, that part # shows a 4L60E gasket on your website. Is that the wrong picture or the wrong number lol? However, if you do by chance have access to new OEM gaskets for the 80E then we'll need to be in touch here in the very near future
Old 09-19-2014, 11:22 AM
TASCAPARTS's Avatar
Yeah Incorrect picture on the site...
Let me know .. Chris
Old 09-19-2014, 02:34 PM
Beautiful, thanks man!
Old 09-19-2014, 06:16 PM
6togo's Avatar
PM sent!!
Old 09-22-2014, 12:29 PM
TASCAPARTS's Avatar
Pm responded Hope we can help you out..
Chris
Old 10-02-2014, 08:58 AM
Troy5061's Avatar
Yes reuseable I had to buy a used one because the new one with my trans kit was too thin and allowed the pan to hit the filter so the pan wouldn't seal correctly.
Old 10-04-2014, 09:58 PM
6togo's Avatar
I got a new gm gasket off EBay for $14
Old 10-06-2014, 12:58 PM
The brown ones? The ones on eBay for $14 are fiber gaskets, not GM. The ones he is selling are black, thicker and reinforce a touch better.
Fiber is preferable over cork, which is the most commonly found, but the black ones are about the only gasket I will re-use if the core comes with it and it cleans up well enough, which unfortunately has been less and less frequently
Old 10-06-2014, 06:19 PM
6togo's Avatar
As i said its a GM gasket the thick black rubber with steel inner core no junk fiber gaskets here!
Quick Reply: 4L80e pan gasket?
