Car slams into drive from park.
Hey fellas. I'm looking to picking up a 2002 Z28 camaro, bone stock. Car has 117k on it but supposedly the 4L60e was rebuilt or replaced at 80k.
When you first start the car and put it into drive it slams pretty hard. All of the other shifts are fine during normal driving and wot. After it's warmed up it doesn't do it as bad.
Fluid is clean and full.
Suggestions?
Suggestions?
Hey fellas. I'm looking to picking up a 2002 Z28 camaro, bone stock. Car has 117k on it but supposedly the 4L60e was rebuilt or replaced at 80k. When you first start the car and put it into drive it slams pretty hard. All of the other shifts are fine during normal driving and wot. After it's warmed up it doesn't do it as bad. Fluid is clean and full. Suggestions?
torque converters have 3 bolts that hold it to the flexplate, if you remove the starter there is an opening to see the flexplate/converter.
put the car in neutral and use a socket to spin the motor over you can check to make sure the torque converter is seated properly and that there isn't slack..
If it's fine, check the shift linkage and make sure every gear is engaging properly.. If it passes all the tests then you most likely have to drop the tranny and have it looked at
If the PCM has any stored codes it could be that the PCM has upped the line pressure to keep the trans from slipping until whatever set the codes is repaired. Scan the PCM for any codes and go from there.
Moderator
It does sound like high line pressure.
Put a trans pressure gauge on it to see what it is in park/Neutral.
Normal pressure at idle in Park is 50-60 psi when warm, about 15psi higher with a shift kit and 10-15psi higher when cold.
My previous f-body started doing exactly what you described at one point. Put some
trans-x in her and it never happened again. May not have permanently fixed the problem but I had no issues for nearly a year until I sold the car.
