4L60E build up.. whats needed?
Old 12-11-2004, 12:39 AM
RollinSScamaro's Avatar
Default 4L60E build up.. whats needed?
Just wondering what is needed to build a 4L60E to handle about 600RWHP? Kevlar cluthes? Corvette Servo? Name any part you can think of.. I was thinking of just buying all the parts and having a tranny guy i know do it for cheap.. instead of buying a brand new Stage 1,2,3 transmission.. I plan on doing a turbo set up in the future so i need a 4L60E trans build.. Thanks guys!
Old 12-11-2004, 06:41 AM
jxaxsxoxn's Avatar
The torque drive package, five pinion planetaries. Kevlar nothing. Alto red friction material, or raybestos. Do everything you can for the 3-4 clutch, use the wide frictions that use only 6 discs but have more surface area than a 9 disc pack.
Then you can break the output shaft.
Old 12-11-2004, 11:27 AM
Alright cool.. I'll write down some of these things to take to my tranny guy.. but is there any packages out there i can buy for a 4L60E that would have all necessary parts for a 600HP 4L60E? If so does anyone have a link or part number? seems like there should be something out there.. Or if there isn't a kit does anyone have a list of every part needed? Thanks for the reply jxaxsxoxn i appreciate it!
Old 12-11-2004, 11:22 PM
Restricted User
Automatics's Avatar
Go to http://www.700r4l60e.com/store/custo...&cat=22&page=1 then change the 3-4 clutch pack to the "Limited Street" (about $25.00 more), & add the HD input drum sleeve & pston. This should handle about 575 - 600 RWHP for awhile. Let me know, if I can be of help?
Old 12-12-2004, 03:06 AM
BoonesZ's Avatar
basically everything.
Old 12-12-2004, 10:16 AM
WicketMike's Avatar
stay away from the alto reds.
get the borg warners for all the drums except for the 3-4. MAKE sure you get the Raybestos Z-pack for the 3-4
Old 12-12-2004, 01:38 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
Save the headaches and buy one from Rossler.
Old 12-12-2004, 01:55 PM
sebss's Avatar
heres a small list i got from a friend :
4L60E Transmission Build Sheet
Gaskets and clutches
1) Overhaul kit
2) 4- reverse input steels
3) 4- reverse input clutches
4) 2- overrunning steels
5) 2- overrunning clutches
6) 5- forward steels
7) 5- forward clutches
8) 1- Raybestos “Z Pak”
9) 1- Hi energy band
10) 5- low/reverse steels
11) 5- low /reverse clutches
Pump Parts
1) 2- Pump rings
2) 1- teflon pump bushing(4l60E)
3) 10- rotor vanes
4) 1- rotor guide
5) 1- TH 350C stator bushing(wide)
6) 1- .490 Sonnax boost valve with O-rings
Hard Parts
1) 1- bushing kit
2) 1-29 element sprag(borg warner)
3) 1-new low/roller clutch
4) 1-“Beast” sun shell
5) 5-new load release springs
6) 1-corvette super servo
Miscellaneous
1) 1- SPX/Filtran filter
2) 1- Sonnax sure cure kit. Includes: pinless accumulators, new AFL valve assembly, new TCC regulator valve assembly, and more
3) 1- B&M, or TransGo shift kit.
4) 1- Pressure Control Solenoid
5) 2- A&B shift solenoids (1-2, and 2-3)
Options
1) Kelvar band
2) Wide Pro Series band(requires new reverse input drum)
3) Raybestos “Blue Plate Special” 3-4 clutches (6)
4) Alto “Red Eagles” 3-4 clutches (9)
5) brand new 4L65E input drum
I went ahead and got a modified version. I Also included a yank ss3800. SOmething like this could run up to 1700 and the options will add a few more here and there.
Good Luck
Old 12-12-2004, 08:59 PM
alright awesome guys! thats helped me out a lot.. I'll have to keep checking around! I'll definately stick with borg warners, and i'll get the Raybestos "Z pak" i'll see what i can do.. i know i can get it all done cheaper than buying a brand new build tranny for $2000.. so i'd rather do all the research myself and get it build.. Thanks a lot guys! very much appreciated!
Old 12-14-2004, 04:39 PM
LS1SS4ever's Avatar
Wink
1) Overhaul kit
Pump Parts
1) 2- Pump rings
3) 10- rotor vanes
4) 1- rotor guide
Hard Parts
1) 1- bushing kit
Miscellaneous
Options
1) Kelvar band
Good Luck
That's a lot for rebuild. Does it cost $1700?
Old 12-15-2004, 02:31 AM
GT Griller's Avatar
GO to Thunder racing i think they have some rebuild kits that are specifically for race applications.
Old 12-15-2004, 03:03 AM
2MuchRiceMakesMeSick's Avatar
There you go. Another vote for rossler
Old 12-15-2004, 10:19 AM
how much is a rossler transmission? because i know i can buy a rebuild kit for about $600 and i know a tranny guuy that can do it for around $400-$500.. Which would save me about $900 for what i'm doing.. Unless you know of a tranny cheaper than $2000 that can handle 600RWHP.. let me know! Thanks
Old 12-15-2004, 10:33 AM
SSnakekiller's Avatar
From my experience, it doesnt depend so much on all the beefy **** you put inside, but more on how it is built. I had a local guy that is respectable do mine with the #24 rebuild package from 4l60-e.com. It has held over 600RWTQ for over 6 mo's with no probs.
This same guy has built 2 trannies I have personally seen run 10's, 1 of them a full street car making 650+RWTQ and his never had any probs after a year and a half, then he sold the car.
What were in these 10 sec trannies?
1. Kevlar Band
2. Shift Kit
3. Servo
Thats it
Old 12-15-2004, 03:43 PM
mark AJB's Avatar
dont foget the vacum modulator. talk to the guys at pro built. iam doing the same thing the kit is 550$.
Old 12-15-2004, 06:09 PM
LS1SS4ever's Avatar
Question
Isn't expensive to hold more power and long life for ur trans
Old 12-16-2004, 08:56 AM
i was wondering that.. how long will a build 4L60E Last? If it doesn't last more than like 30-40,000 then its probably not even worth doing it..
Old 12-16-2004, 06:37 PM
Depends how hard on it you are, depends on a bunch of factors actually. But 30-40 out of a performance 4l60 is askin a lot. if you street drive it and have under 450hp then yeah its possible but if you go to the track a lot or have 500+hp then i dont see it happening without SOMETHING going wrong. might be something minor, but still something. I am sure it is possible, but just not likely...
Quick Reply: 4L60E build up.. whats needed?
