Need help with cooling lines...
Old 02-04-2006, 07:13 PM
LC
LC's Avatar
Default Need help with cooling lines... ALLEN BOLTS WTF!
I am in the process of swapping TCs... I'm following the modern muscle guide..
Everything is going fine, however i'm having a problem with the cooling lines..
MM guide says that you gotta remove some E clips on the top of the tranny..
My cooling lines doesn't go over the tranny.. and i cant find something e shapped.. so.. since i always rush and tend to **** up things, this time i just took a pic and came here for help..
Do i have to remove the lines from the tranny itself?, how do they come off?
The obvious thing is to remove the (npt's?) of the tranny but i dont have any open wrenches... gotta buy some tomorrow if this is the case... (anyone knows the size needed?)
Attached pic..
thanks for any info...
Old 02-04-2006, 07:29 PM
redlined's Avatar
the clips are right at the tip of the pressure fitting that goes into the trans, where your line go into the trans there is a ring on the very top of the nut, the e clip is right there soon as you get clips off the lines pull right out, you can see them in your pic hope that helps........ the clips can be a pain depending on which way they are faceing
Old 02-04-2006, 07:35 PM
LC
LC's Avatar
aaah, now i understand the guide.. thanks redlined... and welcome!
Old 02-04-2006, 07:40 PM
redlined's Avatar
no problem, if you have any more problems just let me know....good luck
Old 02-05-2006, 08:40 AM
FLT
FLT's Avatar
Sounds like you pretty much got it figured out. The use of a sharp pick to get the clips out works best. If you can get on the end of the clip it will work best. If this not an option, use a 18mm wrench and simply unscrew them from he case. Hope this helps..
Old 02-05-2006, 09:33 AM
curtisad's Avatar
go with stubby's and then thank me later!!! TRUST ME!!
Old 02-05-2006, 07:34 PM
LC
LC's Avatar
stubbys?
i have not taked them out yet.. tried a little, got frustrated and went over on the Starter..
NOW.. WTF with those allen bolts on the flywheel to Converter...
So far,
2 ripped sockets
1 broken wrench..
HOW THE HELL DO THEY COME OUT! or with WHAT!????
Old 02-07-2006, 08:46 PM
redlined's Avatar
I had a problem with mine getting them out, i can't remember the size , i think they were metric but like i was saying i had stripped one and i couldn't get it out to save my life i tried everything......Well worse case i took a 4" grinder with a thin cutting blade and cut the foot off the stock converter, as close as the flywheel without touching it, but i had to put a 7" wheel on a 4" grinder in order to reach the rest (like an 1/8")....... well thats my horror story but i wouldn't recomend it for a number of reason unless its the last straw
Old 02-07-2006, 11:26 PM
SUX2BU's Avatar
Originally Posted by Luis Castellanos
stubbys?
So far,
2 ripped sockets
1 broken wrench..
Yeah those bolts SUCK ***!
i had to cut a piece off the heads and use a chisel to turn the ******* loose.
Old 02-07-2006, 11:29 PM
SLIKWS6's Avatar
Did you end up figuring everything out, how did it all turn out? Any advice you would give to someone else? How bout more pictures of the parts of the flywheel that had to be grinded? Thanks, hope everything worked out.
Old 02-08-2006, 10:22 AM
LC
LC's Avatar
The drama is happening here...
https://ls1tech.com/forums/automatic-transmission/449325-fkn-allen-bolts.html
School and Work don't let me work on the car in the week so i will have to wait till the weekend..
So far i'm preparing drill bits, dremel, chisels and hammer...
Old 02-08-2006, 05:56 PM
AK's WS6's Avatar
Yup, a little pick bent at a 90* angle was my best friend that day They also work good for taking off wire clips. I still need to go buy one for my tool box.
