View Poll Results: After my torque converter install
Used a hand held tuner
4
11.43%
Used lap top
16
45.71%
Had puter sent out
0
0%
I Run it, no tune
15
42.86%
Voters: 35. You may not vote on this poll
After your TC install did you tune your car
Old 02-09-2006, 11:44 AM
Bharnz's Avatar
Default After your TC install did you tune your car
How nessesary is it to get a tune after TC install, will it make that much difference, will the puter compinsate,
how many of you just had it installed and run it??
Old 02-09-2006, 12:41 PM
darrensls1's Avatar
I voted used laptop although it was not me that actually did it. New Era Performance (sponor --->) installed my torque converter. Then for only $40 they used HPtuners to delete TM, raise line preasure and I think they also raised the rev limiter. It was money very well spent as my car shifts very crisp and I didn't have to go through the expense of a shift kit.
I have heard that 98-00 models do not usually require a tune or shiftkit (although one or the other is still a good idea). But 2001 & 2002 must have TM deleted to avoid problems and throwing codes.
Old 02-09-2006, 12:55 PM
Moderator
jimmyblue's Avatar
Any converter worth putting in will want shiftpoint MPH
changed, and probably your lockup profile as well.
Old 02-09-2006, 12:58 PM
jdustu's Avatar
i had a handheld tuner, but i hadn't changed anything from before the stall till after.........it could have used a tune, but it drove fine and fast as heck
Old 02-09-2006, 01:36 PM
Bharnz's Avatar
I thank all the voting and feedback, I want this install done right, but I live so far from any reputable sponsors, So I guess I'll get it installed and drive to Chicago for a tune,
I wanted to get a predator.
But from what I gather, it's taking forever to get responses, and tune upgrades, Besides we still have 4 feet of snow and wont be till mid April I can get her out. anyways, I think I'm beginning to suffer from cabin fever. I hate snow, But my business rocks, an my car has low mileage
Old 02-09-2006, 05:01 PM
flyin red TA's Avatar
I was old school and used a hypertech to raise shift points...this was 5 years ago before any real LS1 tuning software was out. I had it all dyno tuned with ls1 edit when that finally came out.
With just raised shift points, it drove fine.
Old 02-09-2006, 07:19 PM
radz282003's Avatar
Get a tune, and realize the true benefit of a TC
Old 02-09-2006, 07:41 PM
LC
LC's Avatar
any advice on what to move?
I got HP Tuners and I'm currently installing a Fuddle 4200/2.5
Old 02-09-2006, 11:14 PM
spanky_55amg's Avatar
i know someone that got a tune on a tci 3800 and it made a world of difference. (with ls1edit at the time)
Old 02-10-2006, 11:27 AM
12secSS's Avatar
Any transmission will feel better than OEM, especially a stalled one. The changes I make on autos usually returns these kind of comments: "the car is a totally different animal" "passing vehicle now is a lot more fun". Just by changing the TCC Apply/Release table, Part-Throttle/WOT Shift tables and the Force Motor table. But each person will like the settings slightly different, obviously.
Old 02-10-2006, 12:07 PM
LC
LC's Avatar
you do tuning Flame?
Old 02-10-2006, 04:00 PM
v8hunter's Avatar
I just installed my fuddle 3400 with a friend last weekend on my car...It was a pain in the ***.
I'd say that you should get it tuned after the install. Mine feels like it needs the line pressure raised so I should get it tuned. It also seems to overrev at the 2-3 shift as the rpms go a touch over 6500 for a second!
My stall is pretty small compared to most, but WOW it made an amazing difference in my car...first gear is pretty much useless under full throttle. That just means I'll have to get drag radials sooner.
I'll probably send my ecu back to PCMs for less very soon to get retuned for the stall.
Old 02-10-2006, 04:08 PM
12secSS's Avatar
Yes I do.
Old 02-11-2006, 05:01 AM
dannyz's Avatar
No tune here. Just put it in and drove.
I have a fuddle 3000 with a 2.0 str.
First gear shift's a tad early, about 5900 rpm, but 2nd to 3rd didn't change.
I would say put it in and drive around for a bit. If your car's not hitting the rev limiter, or shifting below 5800 rpm's, I don't know if a tune is called for.
Old 02-11-2006, 07:51 AM
EDS01SS's Avatar
I didnt tune mine when I installed my TC but I wish I would have.Im having all kinds of issues with the 2nd to 3rd shift bouncing off the rev limiter.
Old 02-12-2006, 12:41 AM
hc2000z28's Avatar
i haven't tuned mine yet but need to. it hits the rev limiter between 1-2 and 2-3 shifts everytime. i even had the limiter increased before the tc install, but i don't remember what RPM it was set at.
Old 02-12-2006, 07:48 PM
The Sad's Avatar
I ran mine for a year w/o a tune. But I had to get a tune after the cam swap. When I got the PCM back (I sent it out) it made a world of difference in the way the tranny acted. It shifted way hard at WOT. I would recommend a tune.
Old 02-13-2006, 10:08 AM
4mula's Avatar
i had speed inc do the basic tune for a converter. it was like 100 bucks or so.
this was about 2 years ago before i was cammed.
Old 02-13-2006, 03:34 PM
spec_j's Avatar
anytime you upgrade something on your car you can tune it, b/c things change everytime you add new things. might not be alot but its enough to matter. but when you go from a stock TC to an aftermarket TC its a must, like other have said tune your can and enjoy the benifits of the new TC
Old 02-13-2006, 11:37 PM
DrkPhx's Avatar
I ran my Yank Y3200 two years without a tune and it was fine. Then I got a good tune on it and it was much better with more precise shifts. When I switched to a TCI 3800 it needed a tune right away because it wouldn't lock.
Quick Reply: After your TC install did you tune your car
