what 60ft time
Old 03-23-2006, 11:25 AM
youngrigo's Avatar
Default what 60ft time
i went to the track yesturday for my first time and i couldnt runn anything better that a 2.2 60ft im just wondering what you other guys are running in the 60ft with out a stall and dr's.......just wondering if there is place for improvment? my best run was 13.3 at 106 w/2.2 60ft
Old 03-23-2006, 01:47 PM
youngrigo's Avatar
really i just want to know what you other a4 are running in the 60ft with out dr's or stall
Old 03-23-2006, 01:53 PM
BlackHawk T/A's Avatar
2.0-2.3 is probably normal with 1.9 being pretty rare for a stock A4.
Old 03-23-2006, 01:55 PM
DOUBT IT's Avatar
Before I threw in the stall, I could regularly cut 1.95 sixty foots on some Firestone Fuzion 245 radials. I just knew how to drive them, and knew how to get the car outta the hole.
Now after only 8 passes with the stall, my average 60 dropped 3 tenths, and the average 1/4 mile pass dropped 6 tenths. I'm sure that I'll be able to do better than that with some practice.
So, average slip before stall looked like this:
1.9x 60' 8.1x 1/8th 12.6x 1/4
Now with the converter and Nitto DR's:
1.6x 60' 7.6x 1/8th 12.0x 1/4
You tell me if the converter was worth it or not...
Just for fun, I'm going to go out tomorrow night at see what that stall will do with my Fuzion street tires at the track. I'll report back in this thread.
Get your 60' down to a 1.9 and 12's are more than possible.
Old 03-23-2006, 03:39 PM
BBATCAR's Avatar
My best was 1.9, I cut the light very well and "mashed" the pedal instead of stomping hard on it, That's the only way I can explain it...and it was my best time on that kind of launch...
Old 03-23-2006, 03:51 PM
4mula's Avatar
2.0s on nittos before stall.
Old 03-23-2006, 04:12 PM
Black_Bird's Avatar
2.02 on 245's, Cooper tires
Old 03-23-2006, 05:04 PM
ARCTICWHITE98Z28's Avatar
2.09 was my best time before stall - that was on Kuhmo Ecsta 275/40/17 tires.
Old 03-23-2006, 05:41 PM
1BAD98LS1's Avatar
2.0's with 275/40/17 Kumho's for me.
Old 03-23-2006, 05:42 PM
s346k's Avatar
2.09 on used 245/50/16 goodyear gsc tires. 32 psi.
Old 03-23-2006, 06:07 PM
8a8mfh's Avatar
2.07 0-60' with a 2002 SS, 3.23 gears, stock size BFG KDWS tires, 13.2 @ 107.
Stock except for an SLP lid, LM exhaust, Transgo shift kit and internal trans work with stock converter, LCA's, PHB, SFC's.
Old 03-23-2006, 06:10 PM
jessedale98's Avatar
before everything i got 1.8s on mt et's
Old 03-23-2006, 07:57 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Best I got before the stall was a 2.07 on 245/50/16 Dayton Daytona. With the mods in sig it cut a 1.76 60ft on the same tires. The stall will definetly help.
Old 04-07-2006, 05:44 PM
youngrigo's Avatar
went to the track yesturday nd ran a new best.....2.125 60ft and ended runing a 13.24 at 106.......thats after i lowered my air pressure because when i checked it, it was at 39psi so i lowered it to 25psi....do you guys think its possible to run 12's how i am, if i get better 60ft? also i would line up and bring my rpms to albout 1100 or 1200 before i launch.....what do you guys with out a stall bring your rpms up to before you launch? this was only my second time out to the track so any advise will be appriciated
Old 04-08-2006, 08:11 AM
99Hawk262's Avatar
I cut a 1.9 with the mods in my sig minus the ported TB and SFC's. This was on BFG KDWS tires at 28 PSI. I didn't stall it up at all, just mashed the pedal on the light. I cut consistent 2.0's and ran consistent 13.0's at 107-108. The 12.9 run I spun a little on the launch but managed to hook quickly and was rewarded with my first 12. I don't know if you could hit 12's as is or not. I can't imagine having much more power than you and I was able to do it. I would think with a good launch you should be able to get there.....or really close at least.
Old 04-08-2006, 08:15 AM
99Hawk262's Avatar
I always ran better times by flashing it rather than stalling it up. I would just barely hold the gas pedal....maybe 100-200 RPM over idle. On the 3rd yellow light, I just floor it and go. If the track has good prep you should hook pretty good.
Old 04-09-2006, 12:17 PM
Frosty's Avatar
The best I cut was a 1.99 on stock 16'' RSA tires. That was before the 17's and the lowering(stock Eagle F1's BLOW!!!). I can't get better than a 2.3 60' but I know it's because of the tires. I picked up these up cheap because I needed tires for the new rims...I can't wait to get these things off lol.
Old 04-09-2006, 01:43 PM
Moderator
jimmyblue's Avatar
Never better than 2.0 on stock or 3000 stall, 3.23
or 3.42s, Stock Torsen or T-2R differential, Goodyear
Eagle F1 or GS-D3 tires. Always tire limited, the only
difference as I mod along has been how much -past-
the 60' mark I continue to spin. You know what you
need to do. If you don't want to drive on drag radials
full time then get a third pair of rims for the play tires.
Old 04-09-2006, 11:55 PM
Greaseymec's Avatar
1.88 60 ft on Nitto DRs. 3000 stall with 3.23 gears. Track prep was pretty bad on a hot day to boot. 13.1 @ 105 mph.
Mec
