How much can the 4L60E handle
Old 07-22-2006, 05:16 PM
Cchris1109's Avatar
Default How much can the 4L60E handle
What would be pushing the limits on a stock 4L60E transmission that is brand new from GM.
I am planning on 150 shot, heads/cam. I was going to do heads and cam first then nitrous or vice versa but down the line, it will be both.
Old 07-22-2006, 05:36 PM
spy2520's Avatar
well consider stock power pushing it for a 4l60e, thats certainly when mine started acting up... some last with pretty good HP numbers though, i guess its all luck because i cant see much correlation with power and 4l60e life...
Old 07-22-2006, 05:48 PM
Blownramair's Avatar
my re built 4l60e could not handle 470 boosted rwhp. went with a 400 w/ brake... oh yea
H
Old 07-22-2006, 06:04 PM
BlackHawk T/A's Avatar
H
Who built it?
Old 07-22-2006, 08:35 PM
Originally Posted by BlackHawk T/A
Who built it?
I dont want to knock the guy, but he said it would handle 500horse and we'll, he was wrong. I ripped it out and put a 400 in w/ a brake. Much happier...
J
Old 07-22-2006, 09:29 PM
AK's WS6's Avatar
It's hard to say. Some of it depends on how you drive it. If you are on the streets and downshifting at WOT often then chances are it won't last long. There is a guy in our club that has a H/C TA with a Yank 4000 stall running 11.2 with his stock trans but it's pretty much a 1/4 mi car only he really doesn't drive it on the street.
Old 07-22-2006, 11:19 PM
Cchris1109's Avatar
i never shift it, i let the computer do it for me and i dont do any launches.
Old 07-23-2006, 02:54 AM
2005suburban's Avatar
Not much!!!
Old 07-23-2006, 04:28 AM
Cchris1109's Avatar
Originally Posted by 2005suburban
Not much!!!
not good haha
Old 07-23-2006, 05:41 AM
PBA
PBA's Avatar
With the stock torque converter, the "realistic" flywheel HP that this will hold (assumuing that everything is in decent shape) is around 450-475, and that is with 3.42's - 3.73's in the rear. There are exceptions to this, but from what I have seen over the years.
Old 07-24-2006, 12:43 PM
Predator T/A's Avatar
the 4l60e was not made for racing it was made for fuel economy and driveabilty........there is alot that you can do to this trany but to make it worth a crap you would have to sink about 800 bucks in parts if you did it yourself and around 3000 to have a reputable builder do it.....for this money i would rather build a th400 for about 350 in parts and will hold just about whatever you put through it....reason being the th400 is all shaft operated and the planets are in the rear of the case (no crappy sunshells and front and rear planets) also the 400 has a center case support which supports the shafts to keep them from bowing under high torque something the 4l60e doesnt have.......also pick up a 4l60e and a 400 and throw them up on the bench and see which one hurts your back the most......the downfall of the 400 is it takes alot of power to turn it just like the c6 it takes about 40-50 horse just to turn the tranny.....anything that i build for racing i build a 400 for it and i do it myself to make sure its done the way i want it done
Old 07-25-2006, 06:29 PM
1999 SS's Avatar
are the th400 3speeds?
Old 07-25-2006, 06:37 PM
Yes, 3 gears.
