What is a good trans fluid?(post up)
Old 08-25-2006, 05:03 AM
98camaroLS1M6's Avatar
Default What is a good trans fluid?(post up)
Post up some brand of trans fluid that you think are superior.
Old 08-25-2006, 07:59 AM
PBA
PBA's Avatar
The Mobil non-synthetic has been a very good fluid for years for the vast majority of street driven vehicles. For a synthetic, Amsoil has proven itself to be one of the best, with Redline doing well also. For severe duty, high horsepower, road racing, Monolec 7500 from Lubrication Engineers is the best I have seen.
Old 08-25-2006, 08:42 AM
GregWS6&z28's Avatar
any Dexron Mercon III will be fine. there is minimally any difference if any between brands. my trans builder said that Napa Dexron would be fine. I have run Valvoline and Castrol.
Old 08-25-2006, 09:33 AM
chewy99ws6's Avatar
I am running Castrol dexron III in mine, no problem so far
Old 08-25-2006, 10:42 AM
Moderator
jimmyblue's Avatar
I use Castrol DexIII because it's one that has
good anti-chatter additives ("meets all"). With
an aftermarket converter and a non-standard
clutch material system you want to find a fluid
that minimizes chattering, hooting, etc. on soft
applies.
Old 08-25-2006, 11:58 AM
Blk00TransAm's Avatar
Lucas Oil
Old 08-26-2006, 11:43 AM
applies.
good to know, thanks.
Old 08-26-2006, 12:39 PM
BlackHawk T/A's Avatar
Dex 3 or 6, nothing fancy.
Old 08-26-2006, 02:28 PM
Loadre's Avatar
I've had good luck with TCI's racing fluid. Supposedly has foam inhibiters and actually lowers fluid temp (whatever) but it has worked well for me.
Old 08-29-2006, 11:45 AM
GFORCE1320's Avatar
I use what ever I run across as long as it's DEX111.
It's pretty much all the same stuff.
