Converter Slip %
Converter Slip %
TH400 converter, 3400 stall I am getting 15% slip on top of 3rd and 10% on top of 2nd. What is everyone else getting.
http://tciauto.com/Products/TechInfo/Calculators.asp#4
Personnally, I would be unhappy with 15% slip on a 3400 stall at redline. A 3400 stall is a relatively tight stall for these motors and if my engine is at 6600 rpm, I don't expect my output shaft to be at 5600 rpm. To me there are 3 possibilities:
1) It is not the right stall for your application.
2) The stall is not well designed.
3) The stall was not built properly.
I'd perfer to see 10% or less slip on the top end of 3rd.
Moderator
I don't trust the slip% number much and prefer
to look at the more straightforward TCC Slip RPM
(or engine RPM - trans input shaft RPM). There I
have seen anything from 250 (TCI 3000) to 350
(TCI 3500, Fuddle 3500). These at 6000RPM. A
TCC slip% would be 3-6% here. 15% would be a
1000RPM slip and that's heinous. But like I said,
I do not trust the TCC Slip% value - I have seen
some crazy results from it (people saying they
have -400% slip etc.).
Ragtop 99 I go with #2
I am trying to find out what kind of results everyone else is getting with a non-lockup converter, so I can justify dropping $600+ on a Yank converter, plus I am open for sugestions if there are beter converters at a reasonable price.
I'd take a look at Yank. They make (made) a converter that would lock-up for a TH 400 which is a nice feature if you take the car on the highway. Might even allow you go a higher stall, assuming that would be of benefit. 3400 is pretty small unless you have 410+ " or FI.
Stall speed is only one consideration in how much a converter will slip when you hit with an extra 200 shot. Not all 3800s will respond the same way.
My suggestion is that you look at a good nitrous converter if you want to spray 200. Going to cost you some extra $$ but a lot of your spray is being burned up as heat in the transmission rather than being used to get you down the track faster.
On our Z28 with a TH400 with a B&M 4000, 8" converter we got about 89% efficiency going through the traps. Or about 11% slip from Engine RPM and Input Shaft RPM. Anything beyond that is not good in my opinion, especially on a smaller stall like your's. My B&M 3000 (2.0 STR) converter in my 2001 SS (4L60E) logged as much as 3% slip (or 97% efficient) at the top of 3rd gear.
Mind you, the size and STR will play a bigger part in efficiency, more so then the actual rpm stall.
