Tranny hp tuners step in need help
Old 03-16-2007, 11:18 AM
dnkynrbk's Avatar
Default Tranny hp tuners step in need help
This is my problem new performa built level 2 yank 3600 stall. When I was at the track this past sat. When I raced the car in D or 3rd off the line was fine pulling the fronts off the ground then when the car shifted into 2nd the car acted like it went to drive. Almost like a 6speed car going from 1st to 4th gear so I had to let off the gas put the car from drive to 2nd and it was fine and just cruised to the end of the track. Next race I started the car in 1st gear took it to 6700 rpm shifted into 2nd rapped that out good and strong then when I shifted into 3rd seems like the transmission tried to engage 3rd and 4th at the same time then the car snap back into power and was fine and ran a 10.50. When im on the street and hammer it the car is fine no problems at all all gears are fine and snap your head back. Everything is turned to stock line pressure and Torque magmt turned off. I talk to frank at performa built and he thinks you have to mess with the rpm and mph table can someone help me?? I also have the race data long on the race with drive on hp tunners. thanks guys.
Old 03-16-2007, 11:25 AM
LilSlo1's Avatar
I'd have to see a scanner log of the problem.
It sounds to me that you have a problem with the shift rpm and mph tables.
Did you get the car tuned after the converter install ?
In order for the trans to shift you have to exceed both the RPM table and the MPH table. I would check your WOT Shift speeds and WOT Shift RPM.
Also I found with my car, I had some troubles getting the car to shift where I wanted it to using the WOT RPM and MPH charts, so I copied the WOT MPH speeds to the regular shift mph table in the 80% to 100% cells.
DO you have HP Tuners ??
If so it may help if you post a scan log and mabey the tune also.
Old 03-16-2007, 11:47 AM
dnkynrbk's Avatar
yes do have hp tunners my buddy has the computer with the program I will get him to post it up on here thanks. does anyone else have what the tables should be set at or is each car different.
Old 03-16-2007, 02:49 PM
LilSlo1's Avatar
It all depends on what rearend gear the car has, and what peoples shift points are.
Old 03-17-2007, 07:08 AM
dnkynrbk's Avatar
my shift point is 6700 with 323 gears...
Old 03-17-2007, 07:56 AM
Ragtop 99's Avatar
I found that the shift table optimized for the street didn't work at the track. I had to back the track shift points down a bit to get it to shift at the same rpm as it would do on the street. I think it was related to wheel spin or lack thereof when running good tires at the track.
Old 03-17-2007, 11:56 PM
02 BLK WS6's Avatar
What you are saying is not necessarily true. My built 4l60e is set to shift @ 6100 rpm 1-2 and 2-3 6000 3-4 my 1-2 and 2-3 shifts are right @ 6050rpm on the street and on the track, rev limiter @ 6400 on a stock internal engine. I set up my clutches to 1/2 the tolerance of a factory rebuild. All I remember is the 3/4 clutch pack set up @ .015 instead of .030-.060. My 2-3 shift is very quick and strong.
Old 03-18-2007, 02:47 AM
LS1Tech Sponsor
performabuilt's Avatar
that clearance we have noted is ideal with aggresive shift close enough to avoid impact break to the drum yet enough to avoid excessive clutch drag
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-18-2007, 11:29 AM
dnkynrbk's Avatar
so set it at that my buddy will post up my run log tonight any other info.please add.
Old 03-20-2007, 11:44 PM
CrazyChris's Avatar
Attached is the HPT log from the N/A pass made in drive. It goes from 1st to 4th almost immediately. Shift speed and shift rpm values, both in WOT and PT, are no where near being exceeded forcing the next gear. So what gives?
Edit: File link on Page 2 of thread.
Old 03-21-2007, 02:49 AM
cablebandit's Avatar
its another setting i bet...vengeance had a car do this...i THINK it was the p0121 setting under engine diagnostics. PM ron @ vengeance racing
Old 03-21-2007, 03:18 PM
dnkynrbk's Avatar
ttt back to the top
Old 03-24-2007, 08:32 AM
dnkynrbk's Avatar
still trying to fix this problem someone out there must know how to tune this out thanks guys
Old 03-24-2007, 08:40 AM
LS1Tech Sponsor
Hey Im not a tuner but would like to study the log but when i try to open it , It looks like arabic or something, What software do you use to open it?
__________________
Call 888-744-6542
Old 03-25-2007, 08:35 PM
dnkynrbk's Avatar
anyone any hp tune. someone has to know how to tune this out
Old 03-25-2007, 08:47 PM
8a8mfh's Avatar
Need to see the tune, the bin file, whatever. I have HPT and whatever it is you posted above is not an HPT file.
Old 03-25-2007, 09:13 PM
LilSlo1's Avatar
I have the same problem, and when I right click and save it wants to save as a web file.
Old 03-27-2007, 01:26 AM
CrazyChris's Avatar
Attachments are not working correctly here. The file is the Standard HP Tuners Log file. It will open in the Scanner.
Link on page 2.
Last edited by CrazyChris; 03-29-2007 at 01:01 AM. Reason: Attachments are not working
Old 03-27-2007, 08:27 AM
8a8mfh's Avatar
I think the bin file will be more help. Thats a run file, it basically repeats what you already said is happening.
Post the bin file.
Old 03-27-2007, 08:48 AM
Moderator
jimmyblue's Avatar
That log file appears to be corrupt (and is downloading
as .htm besides).
