slips in overdrive, hits all other gears fine
Old 03-28-2007, 10:58 PM
kickassT/A's Avatar
Default slips in overdrive, hits all other gears fine
hey guys. i'm on my fourth rebuild, and have about had it with 4l60e's. the transmisson slips its *** off in overdrive, but only if i'm crusing down the freeway, like if i'm trying to maintain a certain speed. if i roll into it, it seems fine, and if i hammer on it it hits the 2-3 shift like a champ, but crusing this thing slips its *** off. any ideas? thanks guys.
Jordan
Old 03-28-2007, 11:58 PM
LS1Tech Sponsor
performabuilt's Avatar
Thats very odd that it would only slip at cruising speeds , Are you sure its not the lockup clutch either not engaging or slipping ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-29-2007, 12:09 AM
kickassT/A's Avatar
i thought it was the converter lock up clutch, which is why i swapped my vig for my current yank... still slipping. i'm guessing a seal? seems to get better with rpms.
Old 03-29-2007, 12:22 AM
LS1Tech Sponsor
Did you change he seal on the input shaft, Also has PWM been disabled, Did you emove the encapsulated check ball from the end of the input shaft. What your describing does not sound like a transmission slip but rather converter clutch slip. Since you swapped converters and still have it you need to look for the underlying cause.
__________________
Call 888-744-6542
Old 03-29-2007, 12:41 AM
kickassT/A's Avatar
check ball is still in the input shaft. not sure about the pwm being disablabled... mikey tunes the car. i appreciate your responses sir. the tranny was built the first time by a gm tech, then 3 more times by a supposedly reputable shop. i've got a nx kit i've been waiting to install for over a year cause my measly 400 rwhp keeps eating transmissions....
Old 03-29-2007, 01:48 AM
Moderator
jimmyblue's Avatar
Stock tune commands 0% line (minimum real
pressure, not 0 PSI) at light cruise and the TCC
on a small diameter converter may just not have
the holding capacity, all the way into the load
before line is eventually bumped up. My old
converter couldn't.
A MAF that's sensing low airflow (load) will push
out the roll-on of additional line and make it worse
potentially.
Whether it's TCC slip or slip in gear can be seen
by the shaft speed ratios and the slip RPM numbers
in the scan tool.
Old 03-29-2007, 08:17 AM
kickassT/A's Avatar
when i get to work today i'll put the tech 2 on and see if i can find any codes or slipping conditions....
Old 03-29-2007, 08:19 AM
LS1Tech Sponsor
Keep us posted on what you find, And you shouldnt be eating trannies at 400 rwhp
__________________
Call 888-744-6542
Old 03-29-2007, 01:07 PM
Moderator
jimmyblue's Avatar
You might want to look at your Dynamic Cylinder
Air value at WOT (if you can use the TechII like
that) as an indication of whether you are getting
a sensible MAF reading; at about 5000RPM you
should see maybe 0.8 g/cyl at least, really more
than that with a cam. If below this I'd try cleaning
the MAF and relook at the g/cyl again. Just because
I see the K&N in your sig. Falsely low load values
can starve the trans of the pressure it needs.
Old 03-29-2007, 11:19 PM
kickassT/A's Avatar
sorry guys, didn't get a chance to mess with my car today... too many customer cars, lol. i'll check that out tomorrow...
Old 04-04-2007, 08:45 PM
kickassT/A's Avatar
ok, no slip codes, 4th gear is comanded, all gov values stay constant, lock up clutch is holding (comanded lockup in 3rd, ran it all the way up, never unlocked) now what?
Old 04-05-2007, 01:10 AM
LS1Tech Sponsor
Hmm thats odd because if lockup was comanded and it slipped in and significant level it should still set a code 1870 componet slipping , Strange . Since you have a tuner can you put the car in lockup and observe the input or engine rpm verses output rpm or speed , If so post it and we can calculate the percentage of slip in overdrive
__________________
Call 888-744-6542
Old 04-05-2007, 01:25 AM
kickassT/A's Avatar
i can try that. what kind of a failure would cause this?
Old 04-05-2007, 01:26 AM
germeezy1's Avatar
Not too highjack but mine seems to not shift into OD for a little while when cold on the freeway. Why does it do that?
Old 04-05-2007, 01:32 AM
kickassT/A's Avatar
to bring ect up
LS1Tech Sponsor
Depends but whats probably actually happening is lock up is disabled, lockup will not occur till the engine hit around 140 degrees, and that will feel like no 4th
__________________
Call 888-744-6542
Old 04-05-2007, 01:55 AM
germeezy1's Avatar
that has to be it, the 4T80E in my Caddy's did the exact same thing. I guess I figured with a built 4L60E that it wouldn't do that, but then again the PCM controls the shifts.
Old 04-05-2007, 04:17 PM
kickassT/A's Avatar
ttt....
Old 04-05-2007, 07:58 PM
KySilverado's Avatar
Watching this thread. My truck is doing the same thing.
Quick Reply: slips in overdrive, hits all other gears fine
