transgo 4L60e-HD2 kit
Old 06-15-2007, 10:02 PM
jlashley2001ss's Avatar
Default transgo 4L60e-HD2 kit
was going to purchase this and was wondering if this is the right kit
http://www.transmissionpartsusa.com/...-035935hd2.htm
what you guys think?
Old 06-15-2007, 10:21 PM
firebirdman469's Avatar
Yes that's the right one...
Old 06-15-2007, 11:00 PM
FLT
FLT's Avatar
I would call them and ask if they have tech service on their products. I sell mine for a bit more but I offer more than most. Also I believe those are both non-sponsored links. Good luck, Vince
Old 06-15-2007, 11:41 PM
i see. so is this product on your website Vince? Looks as if i will be purchasing from you. Thanks Vince!
Old 06-16-2007, 12:54 AM
LS1Tech Sponsor
performabuilt's Avatar
Call us reguardless of whom you purchase from and we will be happy to give you support
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-16-2007, 09:12 AM
Gilbert@Ace Racing's Avatar
Support is very important when considering the installation yourself. If installed correctly the unit must be fully dissasembled. I am sure Vince can steer you in the right direction!
g
Old 06-16-2007, 09:54 AM
al a's Avatar
performabuilt you are a true class act thanks for all the support
Old 06-16-2007, 09:59 AM
Vince...where on your site can i purchase the transgo HD2 kit? i cant find it.
Old 06-16-2007, 11:57 AM
FLT
FLT's Avatar
http://finishlinetrans.com/store/pro...products_id=86 Hope this helps.
Old 06-16-2007, 12:23 PM
Thanks Vince! Just ordered
Old 06-16-2007, 12:48 PM
Tainted's Avatar
ashley performabuilt sent me some instructions on how to modify that HD2 kit to make softer shifts around town but some real bite at WOT. I can post them up for ya if you'd like.
Old 06-16-2007, 01:39 PM
That would be awesome Tainted!!
Old 06-16-2007, 02:15 PM
SCREAMIN's Avatar
Anyone else have this kit in? I coulda swore I had a different transgo kit in my old 96 LT1 camaro... box and everything looked different.
I am currently having the kit above installed in my firebird... hope it works out
Old 06-16-2007, 02:19 PM
Tainted's Avatar
Performabuilt PM'd this info to me. I'll be buying the same kit shortly when I rebuild my A4 to stand up to my new motor.
Shift kit mods
Leave the accumulators stock , But use the largest feed hole sizes, Use no spacers/ Turn the screw in the center of PCS just behind the plug 1/4 turn clockwise. Do everything else according to instructions, This will give you nice part throttle shifts and great performance WOT shifts
Old 06-16-2007, 05:05 PM
FLT
FLT's Avatar
I'm not sure if I agree with turning the set screw in the PCS a 1/4 turn clockwise. With this kit you will be installing a larger boost valve along with a stiffer pressure regulator spring. With that being said you have already elevated the line pressure of the unit. I believe that optimal pressure is between 210-230psi. I usually try to set them on the transmission dyno at 220psi max forward pressure. I mostly have to turn the screw counter clockwise to accomplish this. Just giving you the heads up that excessive pressure can destroy your transmission. I have been working in a shop with a Dyno for almost 18 years. I use to think big pressures with large feed holes were the way to go as well. After breaking bands and blowing drums apart I decided that we needed to tone them down a bit. This has been tested and proven to work the best for me. Basically a lot less failures. Good luck, Vince.
Old 06-16-2007, 05:13 PM
LS1Tech Sponsor
Well to each his own I have also been at this for 22 years and havent seen to many busted drums. But each of us has a different way of getting from A-B and it seems to work. I have seen several different methods to getting the job done that works well. Which is why you wont here me say our way is nessesarily better or not as good than anothers just different.So its all good.
__________________
Call 888-744-6542
Old 06-16-2007, 05:20 PM
FLT
FLT's Avatar
I'm just stating that I believe your methods are creating to much line pressure. I believe this to be hard on the parts mentioned above and also makes the pump work even harder. If you were to put a gauge on your units or Dyno every one that you shipped I believe that you would freak when you saw the pressures that you are making. Good luck, Vince.
Old 06-16-2007, 05:21 PM
big wally 55's Avatar
If it's going to be your first shift kit installation try the recomendations of the kit manufacturer . Like some of you others I have been doing this for 25 years and have installed enough shift kits to know what you can get away with or that works better . If your going to put out the bucks to buy proven technology why not give it a chance first !!! John
Old 06-16-2007, 05:29 PM
LS1Tech Sponsor
Thats good too. Tainter had just ask me how I would set it up and how I do and I told him , Didnt actually plan on it being used in the forum publically allthough thats fine. I have installed the transgo kit exactly according to instructions myself when I have done that I use the smaller feed hole sizes because the part throttle shifts tend to be a little more agressive than I care for with the larger ones.
__________________
Call 888-744-6542
Old 06-16-2007, 05:39 PM
Trust me I havn't left one alone in years !!!!!!!!!!!!!!!!
Quick Reply: transgo 4L60e-HD2 kit
