2nd gear bye bye mod wtf
Driving car to day and 2nd started to slip then it went out trans has 1000 miles on it maybe. Revs out in 1st then shift to 3rd hard let of the gas and hit lightly goes into third Any suggestions?
sounds to me that the 2nd servo seal is bad.
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
yes the 2nd servo (piston)
__________________
Cracked it open today and the fluid smells like rubing alchol ? I know thats not normail everything looks the same though nothing looks broken or damaged Im not sure of the pistion you are talking bout? is it the acumulator? or in the valve body? or in the trans?
the servo is on the side of the transmission it has a circular cover on it reatined by a ring
__________________
Take and remove the 1-2 accumulator housing. This is located in the rear of the oil pan area. It will require that you remove the three 10mm headed bolts. Make sure that you do not have a broken spring or an accumulator piston. Hope fully this will be what is wrong. There is a chance that you have a band that is hurt and slipping in second, but will still hold in 4th do to there being less of a load in 4th gear.
Can you describe how loose?
Does it look like it is "hanging" loose from the drum?
Being able to move it a bit does not necessarily mean it is bad, loose maybe but not necessarily bad.
g
g
Its basicly hanging in there I can move it back and forth about a 3/4 of an inch is that to loose and its the band closes to the motor and I thought they were suppose to have somthing on them like brake shoes it seams like its siting on the drum metal to metal
it has scratches all over it but there not deep wow three sponsers in here to help me I appricate it guys If its a seriuos problem and I got to pull the trany then im gonna do a t56 swap
