Trans slipping in overdrive . . . . .
Old 09-26-2007, 04:52 PM
AronZ28's Avatar
Default Trans slipping in overdrive . . . . .
Yeah this sucks
Car has 106k miles with orginal tranny(stock converter, no cooler). Trans slips going highway speeds, between 65-80mph. If you put the gas down a little to pass or speed up, it shoots the rpms way up(sometimes past 3000). The weird thing is it shifts fine, shifts great going into overdrive.
So what's wrong with it? Am I due for a total rebuild?
Old 09-26-2007, 05:32 PM
LS1Tech Sponsor
performabuilt's Avatar
Sprag could be letting go , 106000 in a performance car is getting on up there, What does the fluid look like
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-27-2007, 12:01 AM
Tech Resident
ChocoTaco369's Avatar
Are you sure it's not just the torque converter locking and unlocking over and over again? Maybe your torque converter clutch is going?
Old 09-27-2007, 12:21 AM
LS1Tech Sponsor
Shooting over 3000 if its not dowshifting would be alotta slip for a stock converter
Originally Posted by ChocoTaco369
Are you sure it's not just the torque converter locking and unlocking over and over again? Maybe your torque converter clutch is going? Oh and when it shoots over 3000 is it still pulling?
__________________
Call 888-744-6542
Old 09-27-2007, 08:35 PM
AronZ28's Avatar
I don't think that's it. Just from the way its acting, it doesn't feel like the torque converter locking and unlocking. The RPMs will shoot up and I'll be holding a steady speed or loosing mph.
Checked the fluid, it looks okay, and no noticble odor. It has been serviced every 30,000 miles(filter and fluid change, not flushed). I did notice if I stuck my nose right up to the dipstick, there was a faint waft of hot tar/fresh asphalt.
Didn't smell anything like the tranny on my Buick when it croaked. That was a smell I'll never forget, and it stunk up the whole car as well. Blew that one up racing my buddy's Pathfinder, probably overheated the sucker.
Old 09-27-2007, 09:08 PM
LS1Tech Sponsor
But at 105k its probably about time for a trans anyway.
__________________
Call 888-744-6542
Old 09-27-2007, 09:26 PM
AronZ28's Avatar
I hate to admit it, but you are absolutely right. I'm going to take it to a tranny shop tommorrow(know anybody good in Murfreesboro or Nashville TN?) and let them look at it. Money is tight right now, but I want this fixed right the first time, so expect a call.
Old 09-27-2007, 09:29 PM
LS1Tech Sponsor
Ill look forward to it and hopefully for your sake its something simple maybe this time till moneys better. Good luck anyway
__________________
Call 888-744-6542
Old 09-28-2007, 12:11 AM
Tech Resident
I wasn't sure what his gearing was. Maybe if he had 4.10's or something, cruising at highway speeds, if it unlocked I could see it shooting to 3000.
Aron, when you say the car shoots up to 3,000 rpms when cruising...what is the normal RPM before it shoots up? Does it shoot up 300 rpms, 500 rpms, 1000 rpms?
Old 09-28-2007, 03:52 PM
AronZ28's Avatar
stock 3.23 gears, so usually 70 is about 2300 rpms.
Old 09-28-2007, 07:21 PM
Tech Resident
So when you're cruising at 70 mph at ~2300 rpms and you get the possible slipping problem, it shoots up 700 rpms to 3000 rpms, then back down to 2300 rpms? What rpm does it shoot to roughly? An increase in how much?
