breaking bellhousings
Old 10-19-2007, 09:38 PM
daniel6718's Avatar
Default breaking bellhousings
friend keeps doing it on the 78 camaro with th350 and a cam only 355 sbc
he runs 8.1's or so and seems to think hes making so0o0o much torque that its beaking them and says people are telling him its the unibody...i think theses people are full of it and his block either isnt flat or he isnt gettin it sitted on the dowel pins correctly or soemthign mechanically wrong...its happened on 2 seperate transmissions
Old 10-19-2007, 09:48 PM
8a8mfh's Avatar
Driveshaft too long?
Old 10-19-2007, 10:40 PM
Gilbert@Ace Racing's Avatar
What mounts is he running?
g
Old 10-20-2007, 12:16 AM
daniel6718's Avatar
they are stock mounts i believe...not solid..i asked that...
btw 8.1 was 1/8 mile
Old 10-20-2007, 07:46 AM
That engine is not making enough power IMHO to break multiple cases... cam only small block? No power adder?
I would think there is something wrong in the mounting. And no, it is not the unibody. F-Bodies have always been unibody construction... think about it.
It is not the body and not the power output, so there can only be a misalignment issue.
g
Old 10-20-2007, 10:12 AM
8a8mfh's Avatar
I had a friend break a few, during a hard launch the rear would squat and shove the driveshaft into the trans because it was too long. Worth checking.
Old 10-20-2007, 12:12 PM
daniel6718's Avatar
really...i dont qute understand...i would think that would break it at the back....i know hes not making enough power or tq...i cut 1.4x and run mid 6's and dont have any problems....any other ideas
Old 10-20-2007, 01:38 PM
Have him make sure the engine and transmission are centered in the frame. Forgot to mention that earlier.
g
Old 10-20-2007, 02:25 PM
FLT
FLT's Avatar
Where do these cases keep breaking? Post some pic's of the broken cases. The only time when I have seen this happen is on wheel stands when the car comes down hard. It does not sound like this car makes that kind of power.
Old 10-20-2007, 04:59 PM
daniel6718's Avatar
i cant get any pics he said it broke like a half moon form the dowel pins across to eachother
Old 10-20-2007, 05:02 PM
I wonder then if his engine aand transmission alignment is correct. If both cases broke similarly, then I would think the problem lies with the engine mounting. I suspect it is high in the back.
Does the transmission rest on top of the crossmember or does he have to do anything unusual to get it to bolt up to the crossmember?
g
Old 10-20-2007, 06:36 PM
GMRACER13's Avatar
If the engine mounts are stock rubber and the tranny mount is solid it can cause a transmission case to break. Also, are the engine mounts in good shape (i.e. not broken or worn out)?
Old 10-20-2007, 08:28 PM
Razor_Blade's Avatar
g
The engine is mounted an inch or so toward the passenger side on second gens from the factory.
Old 10-20-2007, 09:04 PM
Right, that's good info I should have posted, thanks!
Maybe I should have said something more like... make sure the engine is mounted properly, is where it should be. Improper engine and transmission alignment has killed more than a few transmission cases.
g
Old 10-20-2007, 09:51 PM
98turbls1's Avatar
If everything is mountable correctly has he thought of possibly upgrading to a JW??? The stock bellhousing leave a lot to be desired...
Old 10-20-2007, 11:20 PM
Well the JW part is more desireable component in high H/P applications for sure.... but keep in mind this car is not putting down near enough energy to warrant that expense in my opinion.
g
Old 10-21-2007, 02:13 AM
daniel6718's Avatar
well ill get him to check geometry when his new one comes back...pretty sure all his mounts are rubber
wondering if it has to do with him not having a rear sway bar?
Old 10-21-2007, 11:43 AM
I doubt it seriously, I have owned too many of these F-Bodies and still do have a 1st gen Firebird. I know that a mild to nasty small block with a th350 behind is not going to be prone to breaking transmission cases. They just don't.
WHy don't yoou guys give me or John a call tomorrow and we'll see how we can help. There is an alignment issue that has been overlooked here I am sure.
g
Old 10-21-2007, 01:58 PM
8a8mfh's Avatar
It doesn't matter, if the driveshaft was too long it would shove the yoke into the trans going over bumps in the road.
My friend broke two th400's in a mild gen 1 powered 84 c10 because of this. He never raced it.
