Bop Th400
Old 11-13-2007, 06:23 PM
67Firebird455's Avatar
Default Bop Th400
67 bird, s80 or 85 turbo, 408. Debating 4L80E or the TH400 I already have that was attached to a 464ci pontiac solid roller motor. It's already built and only has a couple thousand miles on it, and also has a reverse manual valve body but not transbrake (need one of those). Okay, so... this is a buick olds pontiac style th400, do I need to whack the bell off and get an ultrabell or something? I know for SFI reason I will, but what do I need to bolt this thing to the back of that 408? Suggestions?
Thanks in advance guys.
Tony
Old 11-13-2007, 06:25 PM
BTW - Have a 10" continental 3800 stall for it too brand new that I was using on the 455. Do I need to 86 it on ebay?
Old 11-13-2007, 06:27 PM
LS1Tech Sponsor
performabuilt's Avatar
I would just aquire a Chevy TH400 case and swap the internals over shouldnt cost much to have it done. Not sure what ultra bells cost but I imagine swaping cases would be cheaper ,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-13-2007, 06:28 PM
BTLFEDSS's Avatar
Just get a Chevy Style case from the junkyard and swap the guts,a chevy style bell only has few bolts when bolted to a LSX.I got a core from a local junkyard for $25
BTLFEDSS
Old 11-13-2007, 06:39 PM
Isn't it something like 5 bolts or something that bolt up?
Old 11-13-2007, 07:04 PM
98turbls1's Avatar
yes only 5 bolts... two bottom, two above those and then one stagered to the left...
Old 11-14-2007, 07:23 PM
TravisTA's Avatar
they make adapter plates. check butler performance
Old 11-15-2007, 04:13 PM
Good ol butler... been a while since I've heard that name. I'll check and see. I still really want the 4L80E just because of lockup. Better gas mileage, less trans heat, would be great for cruising on the highway to the coast! =)
