Torque convertor clutch circuit code came up
My car is still sticking in 3rd and the local chevy dealer scanned it and it brought up this code: P0740................So I look it up and the code means , Torque convertor clutch circuit. What should the cost be to fix this and is it something I could do myself ?
so if the dealership knows what they are doing they will check these 2 things first ? Anyway with that code is could be something else ? Trying to make sure they dont rip me off. Thanks for your help
hmmm....that doesn't sound right. Why would they be looking at your ignition switch for that? And that solenoid is literally drop pan, remove the plug from the 3-2 solenoid, then the clip that holds it in...then pull it out. That will let you get to the 2 10mm bolts that hold the TCC solenoid in....yank it out, splice in a new one (about $15) and reinstall. Sounds like a lot but once you look at it you'll smack yourself for even thinking about letting them do it.
Or, you could just replace the harness inside the trans which comes with a new tcc solenoid attached and all new plugs to just eliminate those possibilities for about $64
The most likely cause of this condition may be a loss of voltage to the transmission solenoid power supply circuit.
This condition may also be the result of an incorrect installation of an aftermarket electronic device such as a remote starter or alarm system.
Correction
Important: If the vehicle is equipped with an aftermarket electronic device and the DTCs are being set when the device is being used, verify that the appropriate fuse is being supplied battery voltage during operation. If voltage is not present at this fuse, these DTCs will be set due to lack of voltage at the solenoids. This condition is most likely to occur with an incorrectly installed remote starting system. If this is the case, refer the customer to the installer of the system for corrections. ANY REPAIRS DUE TO AFTERMARKET INSTALLATION OF ACCESSORIES IS A NON-WARRANTABLE ITEM.
1. With the ignition switch in the RUN position, test for battery voltage at the circuit fuse in the transmission solenoid power supply circuit. Refer to the appropriate SI Document for the transmission solenoid power supply circuit information.
2. If battery voltage is present at the fuse, inspect the ignition voltage circuit between the fuse and the transmission for possible opens.
3. If battery voltage is not present at the fuse, test for continuity between the fuse and the ignition switch. If NO continuity is between the fuse and the ignition switch, repair the open in that circuit.
4. If you have continuity between the fuse and the ignition switch, the most likely cause is the ignition switch. Replace the ignition switch using the appropriate Ignition Switch Replacement procedure in SI. Refer to group number 2.188 of the parts catalog for part description and usage of the ignition switch.
Question: They said they replaced solenoid 3:2. Is that the right one to replace if its limp mode and stuck in 3rd ??????
Also I saw the pan and it did have some metal shavings in the bottom of the it. What does that indicate ?
well I replaced the TCC solenoid and wire harness, 3-2 solenoid, PWM TCC solenoid and the filter. Drove the car and same ole crap...........it starts out in a higher gear and never changes gears.............when I get the car going I can downshift manually and have 3rd and 2nd but no first. The service engine soon light did not come on. Guess I will try a tranny shop somebody told me about next week.
Finally got my car back today. After 3 shops, working on it myself and $800 later it is fixed. Thank goodness I found a good mechanic ! It was two bad wires that go to the tranny that was the problem. The tranny had to be removed in order to get to the wires. Man it feels great to have my LS1 back. I been miserable the past month. Soon as I got it home gave it a good bath. I will be out looking for a race tomorrow
