Hitting the rev limiter
Old 05-25-2008, 02:49 PM
Prost79c's Avatar
Default Hitting the rev limiter
I have a 99 WS6 when I have it to the floor, in drive or shifting myself it bangs on the rev limiter and somtimes doesn't shift at all unless I let off it and get back in it again. When it does shift it is very sluggish then picks back up again. any help would be greatly appriciated.
Old 05-25-2008, 03:23 PM
Skidd's Avatar
Mine does the same thing on 2-3 shift while spraying.
Old 05-25-2008, 03:46 PM
LS1Tech Sponsor
performabuilt's Avatar
Could be the 3-4 clutch beginig to fail whats the fluid condition and how many mils on te trans?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-25-2008, 04:09 PM
Skidd's Avatar
MIne has 119,000 on it with a complete tranny service was done not long ago, Dont know the mileage at the time since I didnt have the car then. Fluid is already dark, doesnt smell burt tho. Maybe Prost79c and I are having the same trouble mines just not as bad yet.
Old 05-25-2008, 04:20 PM
camaro98z28's Avatar
All I have to say is. 4L60 is the problem.
Old 05-25-2008, 10:23 PM
Prost79c's Avatar
I have just at 98000 on the car and it does it in all gears 1-2, 2-3, 3-overdrive fluid looks ok no smell of burning. Could it be a computer issue?
Old 05-25-2008, 11:06 PM
MeanWS6's Avatar
your bands are glazed; time for a rebuild or upgrade
common on 4l60e
Old 05-25-2008, 11:19 PM
Prost79c's Avatar
whats a tipical rebuild on a 4l60e cost? Using good aftermarket parts, if nothing serious is wrong. What are some recommended upgrades for performance, other than a converter, I think that i am gonna go with a hughes converter or a vigilante.
Old 05-26-2008, 09:34 AM
Prost79c's Avatar
bump anyone have an idea what kind of $ I am looking at. Thanks
Old 05-26-2008, 11:50 AM
LS1Tech Sponsor
The pricing varies quite a bit but be carefull as just putting in upgraded parts many times is not enough. Alot is in how the unit is built and the special ways things are set up differently than stock. You really should consider a built performance unit from us or one of the other sponsors here. I be leave that would be your best move overall. Please give me a call if I can be of any help
__________________
Call 888-744-6542
Old 05-29-2008, 01:53 AM
Skidd's Avatar
Would a new tranny solve my problem? If its going to end up being a computer issue Ill just switch to a th350.
Old 05-29-2008, 12:20 PM
z28matt's Avatar
yeah my tranny does the same thing some times, how much do your transmitions cost?
Old 05-29-2008, 03:38 PM
radz282003's Avatar
Hmm... I just had my MPH shift points dropped and that fixed the problem...
Old 05-29-2008, 03:47 PM
LS1Tech Sponsor
If the problems with the trans yes it should solve your problem and it likely will, Now on the 350 unless this is a drag only car I would not even consider it with gas prices like they are what little you will save if any on the 350 you will eat up in just a few weeks if you drive much in gas. likely though in all cases here mentioned these are trans issues with the number of miles mentioned
__________________
Call 888-744-6542
Old 05-29-2008, 06:50 PM
Skidd's Avatar
Its not a daily driver, drive it 7 miles to work sometimes and run around town/race on the weekend when Im not working.
Old 05-29-2008, 07:47 PM
LS1Tech Sponsor
still 30 percent loss in fuel economy is alot and adds up real quick
__________________
Call 888-744-6542
Old 05-30-2008, 12:47 AM
Skidd's Avatar
Tough decision since I dont know what im going to do when the lt1 goes. I can do the 350 now and it will be cheaper since I have one in the garage but it will be quite a while before I can drop 2g's on a tranny/converter.
